96'er »
https://forums.nicoclub.com/96-er-u74820.html
Wed Jan 14, 2009 4:40 am
I have 111K on my Q and within the last 10K miles I have flushed the transmission. Recently I noticed that when the transmission shifts from 2nd to 3rd there is a slight hesitation, like the transmission is winding up or slipping.
In the past I have gotten the PO733 code which has to do with improper shifting to 3rd gear position. The FSM states that it could be a control valve sticking, improper solenoid valve operation, malfunctioning servo piston or brake band etc.
Has anyone had a similar problem and what was the corrective action?
Also, beside the transmission flush and the installation of an external transmission cooler, is there anything else I need to do from a preventive maintenance standpoint?
And I did the Transmission Self Diagnosis and got "AT check" as the message. Does this mean that the diagnosis was still running or that the transmission checked out ok? If it was still running the diagnosis, how long do I wait while it is doing its thing?
Modified by 96'er at 9:56 AM 1/14/2009
