Maintenance Engine Oil Indicator?
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
sor326
Hello. I just purchased an Infiniti EX35 two weeks ago. This past weekend, a Maintenance Engine Oil indicator came on. The car only has 800 miles on it. Has anyone had this indicator come on? I didn't set it to do so. Any input would be good. Will be taking into dealer to service this issue...
cjre1
Car: Infiniti EX35 Journey
I have heard of this happening on two owners already. They found out that their oil was low at 500. This is sad to hear, since when you get a new car you expect the dealer to fil it up. I know that within the first 1,000 miles you burn off a little oil, bit not enough for the light to go on.
Other than that, make sure your air filter housings are tight. This might cause the light to go on.
Hope this helps.
dividedhighw
Car: 2008 EX35 AWD (Technology Pkg)
Welcome to NICO, sor326!!
Most likely, your car has the "Maintenance 1" Reminder set at the wrong value. Look in the EX35 Owner's Manual on page 2-23 & also starting on p.4-11.
HTH,David
EXceptional
Car: 2008 Aspen Pearl EX35 Freakin Loaded!
Bump...
EXceptional
Page 4-11 is where it's at (as mentioned above) to reset the Oil Change Reminder.
Mark Booth
When I took delivery of my EX, there were already 3 maintenance reminders set, I assume by the dealer. One was for 1,500 miles, the second for 3,750 and the third for 7,500. I turned them all off!
Mark
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
