Hello,
I was wondering how the brake ratio can be the same using bigger rotors only on front wheels ?
http://www.z1motorsports.com/p...d=141
On Z1 Website we can read :
The additional 2" of rotor diameter vs. stock (11") provides a significant gain in braking leverage which is very evident when the brakes are applied - less force is required to produce the same braking power
This kit uses stock calipers which are balanced to the rest of the braking system. The stock calipers are more than adequate to provide the clamping force necessary but with a larger rotor they actually dont have to clamp as hard to produce the same braking force
and finally :
Quote »By using stock calipers, the entire braking system stays balanced and stock pedal travel is maintained[/quote]
So if I keep stock rear brakes, my car will brake more on front wheels right ?
Can we change that ?
Modified by Nicko500 at 5:24 AM 11/15/2009
