scrutmonkey »
https://forums.nicoclub.com/scrutmonkey-u89865.html
Tue Mar 16, 2010 9:09 pm
Regular maintenance light you just cycle through the menus on the dash to reset or delete...the SES light is different story. If that is what you want Here is the procedure on the 07+ Altimas.
After the code has cycled through once, just hold the ACCEL pedal for 10 seconds and then start you car, the SES should rest soon after.-------------------------------------------------------------Per request, here's the way to put the '07 Altima's into Diagnostic mode:
First off, since our cars don't have a key, getting the car's ignition into the "ON" position is slightly different that all the other cars:
Hop in the Driver's seat, with your keyfob somewhere in the car with you.
Press the Start/Stop button twice to put it into the on position, but do not press the brake, or the clutch, otherwise the engine will start.
After it is in the ON position, count 3 seconds.
Now, within the next 5 seconds, you need to floor and release the accellerator pedal 5 times.
After the 5th release, count off 7 seconds.
After the 7th second, press down and hold the accellerator pedal. After about 10 seconds, the SES light will turn off.
Make sure you have a pen and paper handy at this point.
Release the accellerator pedal at this point, and the light will start to blink.Slow flashes indicate the first number of the 4 digit code, faster flashes indicate the other 3 digits.
There will be a pause of about 1 second between each digit of the code.
10 flashes = 0, 1 flash = 1, etc...
A code 0442 would be:
10 long flashes1 second pause4 short flashes1 second pause4 short flashes1 second pause2 short flashes1 second pause
Then it would repeat, if that was the only code in memory at that time.
To clear all the codes, anytime while the SES light is blinking, just press the accellerator to the floor, and hold it there for at least 10 seconds. When you release the pedal, the codes will have been cleared.
Here's a list of codes (probably not complete):
A/T 1ST GR FNCTN....................................0731A/T 2ND GR FNCTN...................................0732A/T 3RD GR FNCTN...................................0733A/T 4TH GR FNCTN...................................0734A/T TCC S/V FNCTN..................................0744APP SEN 1/CIRC +5.................................0227APP SEN 1/CIRC +5.................................0228APP SEN 2/CIRC +5.................................1227APP SENSOR +5.......................................1228ASCD BRAKE SW......................................1572ASCD SW. ................................................15 64ASCD VHL SPD SEN..................................1574ATF TEMP SEN/CIRC.................................0710BRAKE SW/CIRCUT...................................1805CAN COMM CIRCUIT ................................1000CAN COMM CIRCUIT.................................1001CKP SEN/CIRCUIT.....................................0335CLOSED LOOP-B1....................................1148CMP SEN/CIRC-B1....................................0340CTP LEARNING.........................................1 225CTP LEARNING.........................................1 226CYL 1 MISFIRE.........................................03 01CYL 2 MISFIRE.........................................03 02CYL 3 MISFIRE.........................................03 03CYL 4 MISFIRE.........................................03 04ECM............................................... ..........0605ECM BACK UP CIRCUIT............................1065ECT SEN/CIRCUIT.....................................0117ECT SEN/CIRCUIT....................................0118ECT SENSOR............................................ 0125ENG OVER TEMP.......................................0217ENG OVER TEMP.......................................1217ENGINE SPEED SIG...................................0725ETC ACTR.............................................. ...1121ETC FUNTION CIRC..................................1122ETC MOT............................................... ...1128ETC MOT PWR...........................................1124ETC MOT PWR...........................................1126EVAP GROSS LEAK....................................0455EVAP PURG FLOW/MON............................0441EVAP SMALL LEAK....................................0442EVAP SYS PRES SEN.................................0452EVAP SYS PRES SEN.................................0453EVAP VERY SML LEAK...............................0456EVAP VERY SML LEAK...............................1456FTT SEN/CIRCUIT.....................................0182FTT SEN/CIRCUIT.....................................0183FTT SENSOR............................................ .0181FUEL LEVEL SEN SLOSH...........................0460FUEL LEVEL SEN/CIRC.............................1464FUEL LEVEL SENSOR................................0461FEUL LEVEL SEN/CIRC.............................0462FUEL LEVEL SEN/CIRC.............................0463FUEL SYS-LEAN-B1...................................0171FUEL SYS-RICH-B1...................................0172H02S1(B1)......................................... ......0132H02S1(B1)......................................... ......0133H02S1(B1)......................................... ......0134H02S1(B1)......................................... ......1143H02S1(B1)......................................... ......1144H02S1 HTR (B1).......................................0031H02S1 HTR (B1).......................................0032H02S2(B1)......................................... ......0138H02S2(B1)......................................... ......0139H02S2(B1)......................................... ......1146H02S2(B1)......................................... ......1147H02S2 HTR (B1).......................................0037H02S2 HTR (B1).......................................0038IAT SEN/CIRCUIT.....................................0112IAT SEN/CIRCUIT.....................................0113IAT SENSOR............................................ .0127INT/V TIM CONT-B1..................................0011INT/V TIM CONT-B1..................................1111ISC SYSTEM............................................ .0506ISC SYSTEM............................................ .0507KNOCK SEN/CIRC-B1...............................0327KNOCK SEN/CIRC-B1...............................0328L/PRESS SOL/CIRC..................................0745MAF SEN/CIRCUIT....................................0101MAF SEN/CIRCUIT....................................0102MAF SEN/CIRCUIT....................................0103MAF SENSOR...........................................1 102MIL/CIRC.............................................. ...0650MULTI CYL MISFIRE..................................0300NO DTC DETECTED/FURTHER TEST..........FLASHINGNO DTC (NO TROUBLE CODE)..................0000O/R CLUTCH SOL/CIRC............................1760P-N POS SW/CIRCUIT...............................1706PNP SW/CIRC..........................................0705PURG VOLUME CONT/V............................0444PURG VOLUME CONT/V.............................0445PURG VOLUME CONT/V.............................1444SENSOR POWER/CIRC..............................1229SFT SOL A/CIRC........................................0750SFT SOL B/CIRC........................................0755TCC SOLENOID/CIRC................................0740THERMSTAT FNCTN...................................0128TP SEN 1/CIRC.........................................0222TP SEN 1/CIRC..........................................0223TP SEN 2/CIRC.........................................1223TP SEN 2/CIRC.........................................1224TP SENSOR............................................ ...0221TPV SEN/CIRC A/T....................................1705TW CATALYST SYS-B1...............................0420VC CUT/V BYPASS/V .................................1491VC/V BYPASS/V.........................................1490VEH SPD SEN/CIR AT................................0720VEH SPEED SEN/CIRC..............................0500VENT CONTROL VALVE..............................0447VENT CONTROL VALVE..............................1446VENT CONTROL VALVE..............................1448P0100 Mass or Volume Air Flow Circuit MalfunctionP0101 Mass or Volume Air Flow Circuit Range/Performance ProblemP0102 Mass or Volume Air Flow Circuit Low InputP0103 Mass or Volume Air Flow Circuit High InputP0104 Mass or Volume Air Flow Circuit IntermittentP0105 Manifold Absolute Pressure/Barometric Pressure Circuit MalfunctionP0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance ProblemP0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low InputP0108 Manifold Absolute Pressure/Barometric Pressure Circuit High InputP0109 Manifold Absolute Pressure/Barometric Pressure Circuit IntermittentP0109 Intake Air Temperature Circuit MalfunctionP0111 Intake Air Temperature Circuit Range/Performance ProblemP0112 Intake Air Temperature Circuit Low InputP0113 Intake Air Temperature Circuit High InputP0114 Intake Air Temperature Circuit IntermittentP0115 Engine Coolant Temperature Circuit MalfunctionP0116 Engine Coolant Temperature Circuit Range/Performance ProblemP0117 Engine Coolant Temperature Circuit Low InputP0118 Engine Coolant Temperature Circuit High InputP0119 Engine Coolant Temperature Circuit IntermittentP0120 Throttle/Petal Position Sensor/Switch A Circuit MalfunctionP0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance ProblemP0122 Throttle/Petal Position Sensor/Switch A Circuit Low InputP0123 Throttle/Petal Position Sensor/Switch A Circuit High InputP0124 Throttle/Petal Position Sensor/Switch A Circuit IntermittentP0125 Insufficient Coolant Temperature for Closed Loop Fuel ControlP0126 Insufficient Coolant Temperature for Stable OperationP0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)P0170 Fuel Trim Malfunction (Bank 1)P0171 System too Lean (Bank 1)P0172 System too Rich (Bank 1)P0173 Fuel Trim Malfunction (Bank 2)P0174 System too Lean (Bank 2)P0175 System too Rich (Bank 2)P0176 Fuel Composition Sensor Circuit MalfunctionP0177 Fuel Composition Sensor Circuit Range/PerformanceP0178 Fuel Composition Sensor Circuit Low InputP0179 Fuel Composition Sensor Circuit High InputP0180 Fuel Temperature Sensor A Circuit MalfunctionP0181 Fuel Temperature Sensor A Circuit Range/PerformanceP0182 Fuel Temperature Sensor A Circuit Low InputP0183 Fuel Temperature Sensor A Circuit High InputP0184 Fuel Temperature Sensor A Circuit IntermittentP0185 Fuel Temperature Sensor B Circuit MalfunctionP0186 Fuel Temperature Sensor B Circuit Range/PerformanceP0187 Fuel Temperature Sensor B Circuit Low InputP0188 Fuel Temperature Sensor B Circuit High InputP0189 Fuel Temperature Sensor B Circuit IntermittentP0190 Fuel Rail Pressure Sensor Circuit MalfunctionP0191 Fuel Rail Pressure Sensor Circuit Range/PerformanceP0192 Fuel Rail Pressure Sensor Circuit Low InputP0193 Fuel Rail Pressure Sensor Circuit High InputP0194 Fuel Rail Pressure Sensor Circuit IntermittentP0195 Engine Oil Temperature Sensor MalfunctionP0196 Engine Oil Temperature Sensor Range/PerformanceP0197 Engine Oil Temperature Sensor LowP0198 Engine Oil Temperature Sensor HighP0199 Engine Oil Temperature Sensor IntermittentP0200 Injector Circuit MalfunctionP0201 Injector Circuit Malfunction - Cylinder 1P0202 Injector Circuit Malfunction - Cylinder 2P0203 Injector Circuit Malfunction - Cylinder 3P0204 Injector Circuit Malfunction - Cylinder 4P0205 Injector Circuit Malfunction - Cylinder 5P0206 Injector Circuit Malfunction - Cylinder 6P0207 Injector Circuit Malfunction - Cylinder 7P0208 Injector Circuit Malfunction - Cylinder 8P0209 Injector Circuit Malfunction - Cylinder 9P0210 Injector Circuit Malfunction - Cylinder 10P0211 Injector Circuit Malfunction - Cylinder 11P0212 Injector Circuit Malfunction - Cylinder 12P0213 Cold Start Injector 1 MalfunctionP0214 Cold Start Injector 2 MalfunctionP0215 Engine Shutoff Solenoid MalfunctionP0216 Injection Timing Control Circuit MalfunctionP0217 Engine Overtemp ConditionP0218 Transmission Over Temperature ConditionP0219 Engine Overspeed ConditionP0220 Throttle/Petal Position Sensor/Switch B Circuit MalfunctionP0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance ProblemP0222 Throttle/Petal Position Sensor/Switch B Circuit Low InputP0223 Throttle/Petal Position Sensor/Switch B Circuit High InputP0224 Throttle/Petal Position Sensor/Switch B Circuit IntermittentP0225 Throttle/Petal Position Sensor/Switch C Circuit MalfunctionP0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance ProblemP0227 Throttle/Petal Position Sensor/Switch C Circuit Low InputP0228 Throttle/Petal Position Sensor/Switch C Circuit High InputP0229 Throttle/Petal Position Sensor/Switch C Circuit IntermittentP0230 Fuel Pump Primary Circuit MalfunctionP0231 Fuel Pump Secondary Circuit LowP0232 Fuel Pump Secondary Circuit HighP0233 Fuel Pump Secondary Circuit IntermittentP0234 Engine Overboost ConditionP0235 Turbocharger Boost Sensor A Circuit MalfunctionP0236 Turbocharger Boost Sensor A Circuit Range/PerformanceP0237 Turbocharger Boost Sensor A Circuit LowP0238 Turbocharger Boost Sensor A Circuit HighP0239 Turbocharger Boost Sensor B MalfunctionP0240 Turbocharger Boost Sensor B Circuit Range/PerformanceP0241 Turbocharger Boost Sensor B Circuit LowP0242 Turbocharger Boost Sensor B Circuit HighP0243 Turbocharger Wastegate Solenoid A MalfunctionP0244 Turbocharger Wastegate Solenoid A Range/PerformanceP0245 Turbocharger Wastegate Solenoid A LowP0246 Turbocharger Wastegate Solenoid A HighP0247 Turbocharger Wastegate Solenoid B MalfunctionP0248 Turbocharger Wastegate Solenoid B Range/PerformanceP0249 Turbocharger Wastegate Solenoid B LowP0250 Turbocharger Wastegate Solenoid B HighP0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)P0261 Cylinder 1 Injector Circuit LowP0262 Cylinder 1 Injector Circuit HighP0263 Cylinder 1 Contribution/Balance FaultP0264 Cylinder 2 Injector Circuit LowP0265 Cylinder 2 Injector Circuit HighP0266 Cylinder 2 Contribution/Balance FaultP0267 Cylinder 3 Injector Circuit LowP0268 Cylinder 3 Injector Circuit HighP0269 Cylinder 3 Contribution/Balance FaultP0270 Cylinder 4 Injector Circuit LowP0271 Cylinder 4 Injector Circuit HighP0272 Cylinder 4 Contribution/Balance FaultP0273 Cylinder 5 Injector Circuit LowP0274 Cylinder 5 Injector Circuit HighP0275 Cylinder 5 Contribution/Balance FaultP0276 Cylinder 6 Injector Circuit LowP0277 Cylinder 6 Injector Circuit HighP0278 Cylinder 6 Contribution/Balance FaultP0279 Cylinder 7 Injector Circuit LowP0280 Cylinder 7 Injector Circuit HighP0281 Cylinder 7 Contribution/Balance FaultP0282 Cylinder 8 Injector Circuit LowP0283 Cylinder 8 Injector Circuit HighP0284 Cylinder 8 Contribution/Balance FaultP0285 Cylinder 9 Injector Circuit LowP0286 Cylinder 9 Injector Circuit HighP0287 Cylinder 9 Contribution/Balance FaultP0288 Cylinder 10 Injector Circuit LowP0289 Cylinder 10 Injector Circuit HighP0290 Cylinder 10 Contribution/Balance FaultP0291 Cylinder 11 Injector Circuit LowP0292 Cylinder 11 Injector Circuit HighP0293 Cylinder 11 Contribution/Balance FaultP0294 Cylinder 12 Injector Circuit LowP0295 Cylinder 12 Injector Circuit HighP0296 Cylinder 12 Contribution/Range FaultP0300 Random/Multiple Cylinder Misfire DetectedP0301 Cylinder 1 Misfire DetectedP0302 Cylinder 2 Misfire DetectedP0303 Cylinder 3 Misfire DetectedP0304 Cylinder 4 Misfire DetectedP0305 Cylinder 5 Misfire DetectedP0306 Cylinder 6 Misfire DetectedP0307 Cylinder 7 Misfire DetectedP0308 Cylinder 8 Misfire DetectedP0309 Cylinder 9 Misfire DetectedP0311 Cylinder 11 Misfire DetectedP0312 Cylinder 12 Misfire DetectedP0320 Ignition/Distributor Engine Speed Input Circuit MalfunctionP0321 Ignition/Distributor Engine Speed Input Circuit Range/PerformanceP0322 Ignition/Distributor Engine Speed Input Circuit No SignalP0323 Ignition/Distributor Engine Speed Input Circuit IntermittentP0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)P0332 Knock Sensor 2 Circuit Low Input (Bank 2)P0333 Knock Sensor 2 Circuit High Input (Bank 2)P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)P0335 Crankshaft Position Sensor A Circuit MalfunctionP0336 Crankshaft Position Sensor A Circuit Range/PerformanceP0337 Crankshaft Position Sensor A Circuit Low InputP0338 Crankshaft Position Sensor A Circuit High InputP0339 Crankshaft Position Sensor A Circuit IntermittentP0340 Camshaft Position Sensor Circuit MalfunctionP0341 Camshaft Position Sensor Circuit Range/PerformanceP0342 Camshaft Position Sensor Circuit Low InputP0343 Camshaft Position Sensor Circuit High InputP0344 Camshaft Position Sensor Circuit IntermittentP0350 Ignition Coil Primary/Secondary Circuit MalfunctionP0351 Ignition Coil A Primary/Secondary Circuit MalfunctionP0352 Ignition Coil B Primary/Secondary Circuit MalfunctionP0353 Ignition Coil C Primary/Secondary Circuit MalfunctionP0354 Ignition Coil D Primary/Secondary Circuit MalfunctionP0355 Ignition Coil E Primary/Secondary Circuit MalfunctionP0356 Ignition Coil F Primary/Secondary Circuit MalfunctionP0357 Ignition Coil G Primary/Secondary Circuit MalfunctionP0358 Ignition Coil H Primary/Secondary Circuit MalfunctionP0359 Ignition Coil I Primary/Secondary Circuit MalfunctionP0360 Ignition Coil J Primary/Secondary Circuit MalfunctionP0361 Ignition Coil K Primary/Secondary Circuit MalfunctionP0362 Ignition Coil L Primary/Secondary Circuit MalfunctionP0370 Timing Reference High Resolution Signal A MalfunctionP0371 Timing Reference High Resolution Signal A Too Many PulsesP0372 Timing Reference High Resolution Signal A Too Few PulsesP0373 Timing Reference High Resolution Signal A Intermittent/Erratic PulsesP0374 Timing Reference High Resolution Signal A No PulsesP0375 Timing Reference High Resolution Signal B MalfunctionP0376 Timing Reference High Resolution Signal B Too Many PulsesP0377 Timing Reference High Resolution Signal B Too Few PulsesP0378 Timing Reference High Resolution Signal B Intermittent/Erratic PulsesP0379 Timing Reference High Resolution Signal B No PulsesP0380 Glow Plug/Heater Circuit "A" MalfunctionP0381 Glow Plug/Heater Indicator Circuit MalfunctionP0382 Exhaust Gas Recirculation Flow MalfunctionP0385 Crankshaft Position Sensor B Circuit MalfunctionP0386 Crankshaft Position Sensor B Circuit Range/PerformanceP0387 Crankshaft Position Sensor B Circuit Low InputP0388 Crankshaft Position Sensor B Circuit High InputP0389 Crankshaft Position Sensor B Circuit IntermittentP0400 Exhaust Gas Recirculation Flow MalfunctionP0401 Exhaust Gas Recirculation Flow Insufficient DetectedP0402 Exhaust Gas Recirculation Flow Excessive DetectedP0403 Exhaust Gas Recirculation Circuit MalfunctionP0404 Exhaust Gas Recirculation Circuit Range/PerformanceP0405 Exhaust Gas Recirculation Sensor A Circuit LowP0406 Exhaust Gas Recirculation Sensor A Circuit HighP0407 Exhaust Gas Recirculation Sensor B Circuit LowP0408 Exhaust Gas Recirculation Sensor B Circuit HighP0410 Secondary Air Injection System MalfunctionP0411 Secondary Air Injection System Incorrect Flow DetectedP0412 Secondary Air Injection System Switching Valve A Circuit MalfunctionP0413 Secondary Air Injection System Switching Valve A Circuit OpenP0414 Secondary Air Injection System Switching Valve A Circuit ShortedP0415 Secondary Air Injection System Switching Valve B Circuit MalfunctionP0416 Secondary Air Injection System Switching Valve B Circuit OpenP0417 Secondary Air Injection System Switching Valve B Circuit ShortedP0418 Secondary Air Injection System Relay "A" Circuit MalfunctionP0419 Secondary Air Injection System Relay "B" Circuit MalfunctionP0420 Catalyst System Efficiency Below Threshold (Bank 1)P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)P0422 Main Catalyst Efficiency Below Threshold (Bank 1)P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)P0424 Heated Catalyst Temperature Below Threshold (Bank 1)P0430 Catalyst System Efficiency Below Threshold (Bank 2)P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)P0432 Main Catalyst Efficiency Below Threshold (Bank 2)P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)P0434 Heated Catalyst Temperature Below Threshold (Bank 2)P0440 Evaporative Emission Control System MalfunctionP0441 Evaporative Emission Control System Incorrect Purge FlowP0442 Evaporative Emission Control System Leak Detected (small leak)P0443 Evaporative Emission Control System Purge Control Valve Circuit MalfunctionP0444 Evaporative Emission Control System Purge Control Valve Circuit OpenP0445 Evaporative Emission Control System Purge Control Valve Circuit ShortedP0446 Evaporative Emission Control System Vent Control Circuit MalfunctionP0447 Evaporative Emission Control System Vent Control Circuit OpenP0448 Evaporative Emission Control System Vent Control Circuit ShortedP0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit MalfunctionP0450 Evaporative Emission Control System Pressure Sensor MalfunctionP0451 Evaporative Emission Control System Pressure Sensor Range/PerformanceP0452 Evaporative Emission Control System Pressure Sensor Low InputP0453 Evaporative Emission Control System Pressure Sensor High InputP0454 Evaporative Emission Control System Pressure Sensor IntermittentP0455 Evaporative Emission Control System Leak Detected (gross leak)P0460 Fuel Level Sensor Circuit MalfunctionP0461 Fuel Level Sensor Circuit Range/PerformanceP0462 Fuel Level Sensor Circuit Low InputP0463 Fuel Level Sensor Circuit High InputP0464 Fuel Level Sensor Circuit IntermittentP0465 Purge Flow Sensor Circuit MalfunctionP0466 Purge Flow Sensor Circuit Range/PerformanceP0467 Purge Flow Sensor Circuit Low InputP0468 Purge Flow Sensor Circuit High InputP0469 Purge Flow Sensor Circuit IntermittentP0470 Exhaust Pressure Sensor MalfunctionP0471 Exhaust Pressure Sensor Range/PerformanceP0472 Exhaust Pressure Sensor LowP0473 Exhaust Pressure Sensor HighP0474 Exhaust Pressure Sensor IntermittentP0475 Exhaust Pressure Control Valve MalfunctionP0476 Exhaust Pressure Control Valve Range/PerformanceP0477 Exhaust Pressure Control Valve LowP0478 Exhaust Pressure Control Valve HighP0479 Exhaust Pressure Control Valve IntermittentP0480 Cooling Fan 1 Control Circuit MalfunctionP0481 Cooling Fan 2 Control Circuit MalfunctionP0482 Cooling Fan 3 Control Circuit MalfunctionP0483 Cooling Fan Rationality Check MalfunctionP0484 Cooling Fan Circuit Over CurrentP0485 Cooling Fan Power/Ground Circuit MalfunctionP0500 Vehicle Speed Sensor MalfunctionP0501 Vehicle Speed Sensor Range/PerformanceP0502 Vehicle Speed Sensor Low InputP0503 Vehicle Speed Sensor Intermittent/Erratic/HighP0505 Idle Control System MalfunctionP0506 Idle Control System RPM Lower Than ExpectedP0507 Idle Control System RPM Higher Than ExpectedP0510 Closed Throttle Position Switch MalfunctionP0520 Engine Oil Pressure Sensor/Switch Circuit MalfunctionP0521 Engine Oil Pressure Sensor/Switch Circuit Range/PerformanceP0522 Engine Oil Pressure Sensor/Switch Circuit Low VoltageP0523 Engine Oil Pressure Sensor/Switch Circuit High VoltageP0530 A/C Refrigerant Pressure Sensor Circuit MalfunctionP0531 A/C Refrigerant Pressure Sensor Circuit Range/PerformanceP0532 A/C Refrigerant Pressure Sensor Circuit Low InputP0533 A/C Refrigerant Pressure Sensor Circuit High InputP0534 Air Conditioner Refrigerant Charge LossP0550 Power Steering Pressure Sensor Circuit MalfunctionP0551 Power Steering Pressure Sensor Circuit Range/PerformanceP0552 Power Steering Pressure Sensor Circuit Low InputP0553 Power Steering Pressure Sensor Circuit High InputP0554 Power Steering Pressure Sensor Circuit IntermittentP0560 System Voltage MalfunctionP0561 System Voltage UnstableP0562 System Voltage LowP0563 System Voltage HighP0565 Cruise Control On Signal MalfunctionP0566 Cruise Control Off Signal MalfunctionP0567 Cruise Control Resume Signal MalfunctionP0568 Cruise Control Set Signal MalfunctionP0569 Cruise Control Coast Signal MalfunctionP0570 Cruise Control Accel Signal MalfunctionP0571 Cruise Control/Brake Switch A Circuit MalfunctionP0572 Cruise Control/Brake Switch A Circuit LowP0573 Cruise Control/Brake Switch A Circuit HighP0574 Cruise Control Related MalfunctionP0575 Cruise Control Related MalfunctionP0576 Cruise Control Related MalfunctionP0576 Cruise Control Related MalfunctionP0578 Cruise Control Related MalfunctionP0579 Cruise Control Related MalfunctionP0580 Cruise Control Related MalfunctionP0600 Serial Communication Link MalfunctionP0601 Internal Control Module Memory Check Sum ErrorP0602 Control Module Programming ErrorP0603 Internal Control Module Keep Alive Memory (KAM) ErrorP0604 Internal Control Module Random Access Memory (RAM) ErrorP0605 Internal Control Module Read Only Memory (ROM) ErrorP0606 PCM Processor FaultP0608 Control Module VSS Output "A" MalfunctionP0609 Control Module VSS Output "B" MalfunctionP0620 Generator Control Circuit MalfunctionP0621 Generator Lamp "L" Control Circuit MalfunctionP0622 Generator Field "F" Control Circuit MalfunctionP0650 Malfunction Indicator Lamp (MIL) Control Circuit MalfunctionP0654 Engine RPM Output Circuit MalfunctionP0655 Engine Hot Lamp Output Control Circuit MalfucntionP0656 Fuel Level Output Circuit MalfunctionP0700 Transmission Control System MalfunctionP0701 Transmission Control System Range/PerformanceP0702 Transmission Control System ElectricalP0703 Torque Converter/Brake Switch B Circuit MalfunctionP0704 Clutch Switch Input Circuit MalfunctionP0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)P0706 Transmission Range Sensor Circuit Range/PerformanceP0707 Transmission Range Sensor Circuit Low InputP0708 Transmission Range Sensor Circuit High InputP0709 Transmission Range Sensor Circuit IntermittentP0710 Transmission Fluid Temperature Sensor Circuit MalfunctionP0711 Transmission Fluid Temperature Sensor Circuit Range/PerformanceP0712 Transmission Fluid Temperature Sensor Circuit Low InputP0713 Transmission Fluid Temperature Sensor Circuit High InputP0714 Transmission Fluid Temperature Sensor Circuit IntermittentP0715 Input/Turbine Speed Sensor Circuit MalfunctionP0716 Input/Turbine Speed Sensor Circuit Range/PerformanceP0717 Input/Turbine Speed Sensor Circuit No SignalP0718 Input/Turbine Speed Sensor Circuit IntermittentP0719 Torque Converter/Brake Switch B Circuit LowP0720 Output Speed Sensor Circuit MalfunctionP0721 Output Speed Sensor Range/PerformanceP0722 Output Speed Sensor No SignalP0723 Output Speed Sensor IntermittentP0724 Torque Converter/Brake Switch B Circuit HighP0725 Engine Speed input Circuit MalfunctionP0726 Engine Speed Input Circuit Range/PerformanceP0727 Engine Speed Input Circuit No SignalP0728 Engine Speed Input Circuit IntermittentP0730 Incorrect Gear RatioP0731 Gear 1 Incorrect ratioP0732 Gear 2 Incorrect ratioP0733 Gear 3 Incorrect ratioP0734 Gear 4 Incorrect ratioP0735 Gear 5 Incorrect ratioP0736 Reverse incorrect gear ratioP0740 Torque Converter Clutch Circuit MalfuctionP0741 Torque Converter Clutch Circuit Performance or Stuck OffP0742 Torque Converter Clutch Circuit Stuck OnP0743 Torque Converter Clutch Circuit ElectricalP0744 Torque Converter Clutch Circuit IntermittentP0745 Pressure Control Solenoid MalfunctionP0746 Pressure Control Solenoid Performance or Stuck OffP0747 Pressure Control Solenoid Stuck OnP0748 Pressure Control Solenoid ElectricalP0749 Pressure Control Solenoid IntermittentP0750 Shift Solenoid A MalfunctionP0751 Shift Solenoid A Performance or Stuck OffP0752 Shift Solenoid A Stuck OnP0753 Shift Solenoid A ElectricalP0754 Shift Solenoid A IntermittentP0755 Shift Solenoid B MalfunctionP0756 Shift Solenoid B Performance or Stuck OffP0757 Shift Solenoid B Stuck OnP0758 Shift Solenoid B ElectricalP0759 Shift Solenoid B IntermittentP0760 Shift Solenoid C MalfunctionP0761 Shift Solenoid C Performance or Stuck OffP0762 Shift Solenoid C Stuck OnP0763 Shift Solenoid C ElectricalP0764 Shift Solenoid C IntermittentP0765 Shift Solenoid D MalfunctionP0766 Shift Solenoid D Performance or Stuck OffP0767 Shift Solenoid D Stuck OnP0768 Shift Solenoid D ElectricalP0769 Shift Solenoid D IntermittentP0770 Shift Solenoid E MalfunctionP0771 Shift Solenoid E Performance or Stuck OffP0772 Shift Solenoid E Stuck OnP0773 Shift Solenoid E ElectricalP0774 Shift Solenoid E IntermittentP0780 Shift MalfunctionP0781 1-2 Shift MalfunctionP0782 2-3 Shift MalfunctionP0783 3-4 Shift MalfunctionP0784 4-5 Shift MalfunctionP0785 Shift/Timing Solenoid MalfunctionP0786 Shift/Timing Solenoid Range/PerformanceP0787 Shift/Timing Solenoid LowP0788 Shift/Timing Solenoid HighP0789 Shift/Timing Solenoid IntermittentP0790 Normal/Performance Switch Circuit MalfunctionP0801 Reverse Inhibit Control Circuit MalfunctionP0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit MalfunctionP0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunctionhere was my list i made....
DTC Codes - P0100-P0199 – Fuel and Air Metering
P0100 Mass or Volume Air Flow Circuit Malfunction P0101 Mass or Volume Air Flow Circuit Range/Performance Problem P0102 Mass or Volume Air Flow Circuit Low Input P0103 Mass or Volume Air Flow Circuit High Input P0104 Mass or Volume Air Flow Circuit Intermittent P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent P0109 Intake Air Temperature Circuit Malfunction P0111 Intake Air Temperature Circuit Range/Performance Problem P0112 Intake Air Temperature Circuit Low Input P0113 Intake Air Temperature Circuit High Input P0114 Intake Air Temperature Circuit Intermittent P0115 Engine Coolant Temperature Circuit Malfunction P0116 Engine Coolant Temperature Circuit Range/Performance Problem P0117 Engine Coolant Temperature Circuit Low Input P0118 Engine Coolant Temperature Circuit High Input P0119 Engine Coolant Temperature Circuit Intermittent P0120 Throttle Position Sensor/Switch A Circuit Malfunction P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem P0122 Throttle Position Sensor/Switch A Circuit Low Input P0123 Throttle Position Sensor/Switch A Circuit High Input P0124 Throttle Position Sensor/Switch A Circuit Intermittent P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control P0126 Insufficient Coolant Temperature for Stable Operation P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1) P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I) P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1) P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1) P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1) P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2) P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2) P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2) P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2) P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2) P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3) P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3) P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3) P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3) P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3) P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3) P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I) P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I) P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1) P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1) P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1) P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1) P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2) P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2) P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2) P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2) P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2) P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2) P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3) P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3) P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3) P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3) P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3) P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3) P0170 Fuel Trim Malfunction (Bank 1) P0171 System too Lean (Bank 1) P0172 System too Rich (Bank 1) P0173 Fuel Trim Malfunction (Bank 2) P0174 System too Lean (Bank 2) P0175 System too Rich (Bank 2) P0176 Fuel Composition Sensor Circuit Malfunction P0177 Fuel Composition Sensor Circuit Range/Performance P0178 Fuel Composition Sensor Circuit Low Input P0179 Fuel Composition Sensor Circuit High Input P0180 Fuel Temperature Sensor A Circuit Malfunction P0181 Fuel Temperature Sensor A Circuit Range/Performance P0182 Fuel Temperature Sensor A Circuit Low Input P0183 Fuel Temperature Sensor A Circuit High Input P0184 Fuel Temperature Sensor A Circuit Intermittent P0185 Fuel Temperature Sensor B Circuit Malfunction P0186 Fuel Temperature Sensor B Circuit Range/Performance P0187 Fuel Temperature Sensor B Circuit Low Input P0188 Fuel Temperature Sensor B Circuit High Input P0189 Fuel Temperature Sensor B Circuit Intermittent P0190 Fuel Rail Pressure Sensor Circuit Malfunction P0191 Fuel Rail Pressure Sensor Circuit Range/Performance P0192 Fuel Rail Pressure Sensor Circuit Low Input P0193 Fuel Rail Pressure Sensor Circuit High Input P0194 Fuel Rail Pressure Sensor Circuit Intermittent P0195 Engine Oil Temperature Sensor Malfunction P0196 Engine Oil Temperature Sensor Range/Performance P0197 Engine Oil Temperature Sensor Low P0198 Engine Oil Temperature Sensor High P0199 Engine Oil Temperature Sensor Intermittent
DTC Codes - P0200-P0299 – Fuel and Air Metering (Injector Circuit)
P0200 Injector Circuit Malfunction P0201 Injector Circuit Malfunction - Cylinder 1 P0202 Injector Circuit Malfunction - Cylinder 2 P0203 Injector Circuit Malfunction - Cylinder 3 P0204 Injector Circuit Malfunction - Cylinder 4 P0205 Injector Circuit Malfunction - Cylinder 5 P0206 Injector Circuit Malfunction - Cylinder 6 P0207 Injector Circuit Malfunction - Cylinder 7 P0208 Injector Circuit Malfunction - Cylinder 8 P0209 Injector Circuit Malfunction - Cylinder 9 P0210 Injector Circuit Malfunction - Cylinder 10 P0211 Injector Circuit Malfunction - Cylinder 11 P0212 Injector Circuit Malfunction - Cylinder 12 P0213 Cold Start Injector 1 Malfunction P0214 Cold Start Injector 2 Malfunction P0215 Engine Shutoff Solenoid Malfunction P0216 Injection Timing Control Circuit Malfunction P0217 Engine Overtemp Condition P0218 Transmission Over Temperature Condition P0219 Engine Overspeed Condition P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent P0230 Fuel Pump Primary Circuit Malfunction P0231 Fuel Pump Secondary Circuit Low P0232 Fuel Pump Secondary Circuit High P0233 Fuel Pump Secondary Circuit Intermittent P0234 Engine Overboost Condition P0235 Turbocharger Boost Sensor A Circuit Malfunction P0236 Turbocharger Boost Sensor A Circuit Range/Performance P0237 Turbocharger Boost Sensor A Circuit Low P0238 Turbocharger Boost Sensor A Circuit High P0239 Turbocharger Boost Sensor B Malfunction P0240 Turbocharger Boost Sensor B Circuit Range/Performance P0241 Turbocharger Boost Sensor B Circuit Low P0242 Turbocharger Boost Sensor B Circuit High P0243 Turbocharger Wastegate Solenoid A Malfunction P0244 Turbocharger Wastegate Solenoid A Range/Performance P0245 Turbocharger Wastegate Solenoid A Low P0246 Turbocharger Wastegate Solenoid A High P0247 Turbocharger Wastegate Solenoid B Malfunction P0248 Turbocharger Wastegate Solenoid B Range/Performance P0249 Turbocharger Wastegate Solenoid B Low P0250 Turbocharger Wastegate Solenoid B High P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector) P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector) P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector) P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector) P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector) P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector) P0257 Injection Pump Fuel Metering Control "B" Range/Performance Injector) P0258 Injection Pump Fuel Metering Control "B" Low (Cam/R P0259 Injection Pump Fuel Metering Control "B" High (Cam/R P0260 Injection Pump Fuel Metering Control "B" Intermittent Injector) P0261 Cylinder I Injector Circuit Low P0262 Cylinder I Injector Circuit High P0263 Cylinder I Contribution/Balance Fault P0264 Cylinder 2 Injector Circuit Low P0265 Cylinder 2 Injector Circuit High P0266 Cylinder 2 Contribution/Balance Fault P0267 Cylinder 3 Injector Circuit Low P0268 Cylinder 3 Injector Circuit High P0269 Cylinder 3 Contribution/Balance Fault P0270 Cylinder 4 Injector Circuit Low P0271 Cylinder 4 Injector Circuit High P0272 Cylinder 4 Contribution/Balance Fault P0273 Cylinder 5 Injector Circuit Low P0274 Cylinder 5 Injector Circuit High P0275 Cylinder S Contribution/Balance Fault P0276 Cylinder 6 Injector Circuit Low P0277 Cylinder 6 Injector Circuit High P0278 Cylinder 6 Contribution/Balance Fault P0279 Cylinder 7 Injector Circuit Low P0280 Cylinder 7 Injector Circuit High P0281 Cylinder 7 Contribution/Balance Fault P0282 Cylinder 8 Injector Circuit Low P0283 Cylinder 8 Injector Circuit High P0284 Cylinder 8 Contribution/Balance Fault P0285 Cylinder 9 Injector Circuit Low P0286 Cylinder 9 Injector Circuit High P0287 Cylinder 9 Contribution/Balance Fault P0288 Cylinder 10 Injector Circuit Low P0289 Cylinder 10 Injector Circuit High P0290 Cylinder 10 Contribution/Balance Fault P0291 Cylinder 11 Injector Circuit Low P0292 Cylinder 11 Injector Circuit High P0293 Cylinder 11 Contribution/Balance Fault P0294 Cylinder 12 Injector Circuit Low P0295 Cylinder 12 Injector Circuit High P0296 Cylinder 12 Contribution/Range Fault
DTC Codes - P0300-P0399 – Ignition System or Misfire
P0300 Random/Multiple Cylinder Misfire DetectedP0301 Cylinder 1 Misfire DetectedP0302 Cylinder 2 Misfire DetectedP0303 Cylinder 3 Misfire DetectedP0304 Cylinder 4 Misfire DetectedP0305 Cylinder 5 Misfire DetectedP0306 Cylinder 6 Misfire DetectedP0307 Cylinder 7 Misfire DetectedP0308 Cylinder 8 Misfire DetectedP0309 Cylinder 9 Misfire DetectedP0310 Cylinder 10 Misfire DetectedP0311 Cylinder 11 Misfire DetectedP0312 Cylinder 12 Misfire DetectedP0320 Ignition/Distributor Engine Speed Input Circuit MalfunctionP0321 Ignition/Distributor Engine Speed Input Circuit Range/PerformanceP0322 Ignition/Distributor Engine Speed Input Circuit No SignalP0323 Ignition/Distributor Engine Speed Input Circuit IntermittentP0325 Knock Sensor 1 Circuit Malfunction (Bank I or Single Sensor)P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)P0327 Knock Sensor 1 Circuit Low Input (Bank I or Single Sensor)P0328 Knock Sensor 1 Circuit High Input (Bank I or Single Sensor)P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)P0332 Knock Sensor 2 Circuit Low Input (Bank 2)P0333 Knock Sensor 2 Circuit High Input (Bank 2)P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)P0335 Crankshaft Position Sensor A Circuit MalfunctionP0336 Crankshaft Position Sensor A Circuit Range/PerformanceP0337 Crankshaft Position Sensor A Circuit Low InputP0338 Crankshaft Position Sensor A Circuit High InputP0339 Crankshaft Position Sensor A Circuit IntermittentP0340 Camshaft Position Sensor Circuit MalfunctionP0341 Camshaft Position Sensor Circuit Range/PerformanceP0342 Camshaft Position Sensor Circuit Low InputP0343 Camshaft Position Sensor Circuit High InputP0344 Camshaft Position Sensor Circuit IntermittentP0350 Ignition Coil Primary/Secondary Circuit MalfunctionP0351 Ignition Coil A Primary/Secondary Circuit MalfunctionP0352 Ignition Coil B Primary/Secondary Circuit MalfunctionP0353 Ignition Coil C Primary/Secondary Circuit MalfunctionP0354 Ignition Coil D Primary/Secondary Circuit MalfunctionP0355 Ignition Coil E Primary/Secondary Circuit MalfunctionP0356 Ignition Coil F Primary/Secondary Circuit MalfunctionP0357 Ignition Coil G Primary/Secondary Circuit MalfunctionP0358 Ignition Coil H Primary/Secondary Circuit MalfunctionP0359 Ignition Coil I Primary/Secondary Circuit MalfunctionP0360 Ignition Coil J Primary/Secondary Circuit MalfunctionP0361 Ignition Coil K Primary/Secondary Circuit MalfunctionP0362 Ignition Coil L Primary/Secondary Circuit MalfunctionP0370 Timing Reference High Resolution Signal A MalfunctionP0371 Timing Reference High Resolution Signal A Too Many PulsesP0372 Timing Reference High Resolution Signal A Too Few PulsesP0373 Timing Reference High Resolution Signal A Intermittent/Erratic PulsesP0374 Timing Reference High Resolution Signal A No PulsesP0375 Timing Reference High Resolution Signal B MalfunctionP0376 Timing Reference High Resolution Signal B Too Many PulsesP0377 Timing Reference High Resolution Signal B Too Few PulsesP0378 Timing Reference High Resolution Signal B Intermittent/Erratic PulsesP0379 Timing Reference High Resolution Signal B No PulsesP0380 Glow Plug/Heater Circuit "A" MalfunctionP0381 Glow Plug/Heater Indicator Circuit MalfunctionP0382 Exhaust Gas Recirculation Flow MalfunctionP0385 Crankshaft Position Sensor B Circuit MalfunctionP0386 Crankshaft Position Sensor B Circuit Range/PerformanceP0387 Crankshaft Position Sensor B Circuit Low InputP0388 Crankshaft Position Sensor B Circuit High InputP0389 Crankshaft Position Sensor B Circuit Intermittent
DTC Codes - P0400-P0499 – Auxiliary Emissions Controls
P0400 Exhaust Gas Recirculation Flow MalfunctionP0401 Exhaust Gas Recirculation Flow Insufficient DetectedP0402 Exhaust Gas Recirculation Flow Excessive DetectedP0403 Exhaust Gas Recirculation Circuit MalfunctionP0404 Exhaust Gas Recirculation Circuit Range/PerformanceP0405 Exhaust Gas Recirculation Sensor A Circuit LowP0406 Exhaust Gas Recirculation Sensor A Circuit HighP0407 Exhaust Gas Recirculation Sensor B Circuit LowP0408 Exhaust Gas Recirculation Sensor B Circuit HighP0410 Secondary Air Injection System MalfunctionP0411 Secondary Air Injection System Incorrect Flow DetectedP0412 Secondary Air Injection System Switching Valve A Circuit MalfunctionP0413 Secondary Air Injection System Switching Valve A Circuit OpenP0414 Secondary Air Injection System Switching Valve A Circuit ShortedP0415 Secondary Air Injection System Switching Valve B Circuit MalfunctionP0416 Secondary Air Injection System Switching Valve B Circuit OpenP0417 Secondary Air Injection System Switching Valve B Circuit ShortedP0418 Secondary Air Injection System Relay ‘A" Circuit MalfunctionP0419 Secondary Air Injection System Relay "B’ Circuit MalfunctionP0420 Catalyst System Efficiency Below Threshold (Bank 1)P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)P0422 Main Catalyst Efficiency Below Threshold (Bank 1)P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)P0424 Heated Catalyst Temperature Below Threshold (Bank 1)P0430 Catalyst System Efficiency Below Threshold (Bank 2)P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)P0432 Main Catalyst Efficiency Below Threshold (Bank 2)P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)P0434 Heated Catalyst Temperature Below Threshold (Bank 2)P0440 Evaporative Emission Control System MalfunctionP0441 Evaporative Emission Control System Incorrect Purge FlowP0442 Evaporative Emission Control System Leak Detected (small leak)P0443 Evaporative Emission Control System Purge Control Valve CircuitP0444 Evaporative Emission Control System Purge Control Valve CircuitP0445 Evaporative Emission Control System Purge Control Valve Circuit ShortedP0446 Evaporative Emission Control System Vent Control Circuit MalfunctionP0447 Evaporative Emission Control System Vent Control Circuit OpenP0448 Evaporative Emission Control System Vent Control Circuit ShortedP0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit MalfunctionP0450 Evaporative Emission Control System Pressure Sensor MalfunctionP0451 Evaporative Emission Control System Pressure Sensor Range/PerformanceP0452 Evaporative Emission Control System Pressure Sensor Low InputP0453 Evaporative Emission Control System Pressure Sensor High InputP0454 Evaporative Emission Control System Pressure Sensor IntermittentP0455 Evaporative Emission Control System Leak Detected (gross leak)P0460 Fuel Level Sensor Circuit MalfunctionP0461 Fuel Level Sensor Circuit Range/PerformanceP0462 Fuel Level Sensor Circuit Low InputP0463 Fuel Level Sensor Circuit High InputP0464 Fuel Level Sensor Circuit IntermittentP0465 Purge Flow Sensor Circuit MalfunctionP0466 Purge Flow Sensor Circuit Range/PerformanceP0467 Purge Flow Sensor Circuit Low InputP0468 Purge Flow Sensor Circuit High InputP0469 Purge Flow Sensor Circuit IntermittentP0470 Exhaust Pressure Sensor MalfunctionP0471 Exhaust Pressure Sensor Range/PerformanceP0472 Exhaust Pressure Sensor LowP0473 Exhaust Pressure Sensor HighP0474 Exhaust Pressure Sensor IntermittentP0475 Exhaust Pressure Control Valve MalfunctionP0476 Exhaust Pressure Control Valve Range/PerformanceP0477 Exhaust Pressure Control Valve LowP0478 Exhaust Pressure Control Valve HighP0479 Exhaust Pressure Control Valve IntermittentP0480 Cooling Fan I Control Circuit MalfunctionP0481 Cooling Fan 2 Control Circuit MalfunctionP0482 Cooling Fan 3 Control Circuit MalfunctionP0483 Cooling Fan Rationality Check MalfunctionP0484 Cooling Fan Circuit Over CurrentP0485 Cooling Fan Power/Ground Circuit Malfunction
DTC Codes - P0500-P0599 – Vehicle Speed Controls and Idle Control System
DTC Codes - P0600-P0699 – Computer Output Circuit
P0600 Serial Communication Link MalfunctionP0601 Internal Control Module Memory Check Sum ErrorP0602 Control Module Programming ErrorP0603 Internal Control Module Keep Alive Memory (KAM) ErrorP0604 Internal Control Module Random Access Memory (RAM) ErrorP0605 Internal Control Module Read Only Memory (ROM) ErrorP0606 PCM Processor FaultP0608 Control Module VSS Output "A’ MalfunctionP0609 Control Module VSS Output "B" MalfunctionP0620 Generator Control Circuit MalfunctionP0621 Generator Lamp "L" Control Circuit MalfunctionP0622 Generator Field "F" Control Circuit MalfunctionP0650 Malfunction Indicator Lamp (MIL) Control Circuit MalfunctionP0654 Engine RPM Output Circuit MalfunctionP0655 Engine Hot Lamp Output Control Circuit MalfunctionP0656 Fuel Level Output Circuit Malfunction
DTC Codes - P0700-P0899 – Transmission
P0700 Transmission Control System MalfunctionP0701 Transmission Control System Range/PerformanceP0702 Transmission Control System ElectricalP0703 Torque Converter/Brake Switch B Circuit MalfunctionP0704 Clutch Switch Input Circuit MalfunctionP0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)P0706 Transmission Range Sensor Circuit Range/PerformanceP0707 Transmission Range Sensor Circuit Low InputP0708 Transmission Range Sensor Circuit High InputP0709 Transmission Range Sensor Circuit IntermittentP0710 Transmission Fluid Temperature Sensor Circuit MalfunctionP0711 Transmission Fluid Temperature Sensor Circuit Range/PerformanceP0712 Transmission Fluid Temperature Sensor Circuit Low InputP0713 Transmission Fluid Temperature Sensor Circuit High InputP0714 Transmission Fluid Temperature Sensor Circuit IntermittentP0715 Input/Turbine Speed Sensor Circuit MalfunctionP0716 Input/Turbine Speed Sensor Circuit Range/PerformanceP0717 Input/Turbine Speed Sensor Circuit No SignalP0718 Input/Turbine Speed Sensor Circuit IntermittentP0719 Torque Converter/Brake Switch B Circuit LowP0720 Output Speed Sensor Circuit MalfunctionP0721 Output Speed Sensor Range/PerformanceP0722 Output Speed Sensor No SignalP0723 Output Speed Sensor IntermittentP0724 Torque Converter/Brake Switch B Circuit HighP0725 Engine Speed input Circuit MalfunctionP0726 Engine Speed Input Circuit Range/PerformanceP0727 Engine Speed Input Circuit No SignalP0728 Engine Speed Input Circuit IntermittentP0730 Incorrect Gear RatioP0731 Gear I Incorrect ratioP0732 Gear 2 Incorrect ratioP0733 Gear 3 Incorrect ratioP0734 Gear 4 Incorrect ratioP0735 Gear 5 Incorrect ratioP0736 Reverse incorrect gear ratioP0740 Torque Converter Clutch Circuit MalfunctionP0741 Torque Converter Clutch Circuit Performance or Stuck OffP0742 Torque Converter Clutch Circuit Stock OnP0743 Torque Converter Clutch Circuit ElectricalP0744 Torque Converter Clutch Circuit IntermittentP0745 Pressure Control Solenoid MalfunctionP0746 Pressure Control Solenoid Performance or Stuck OffP0747 Pressure Control Solenoid Stuck OnP0748 Pressure Control Solenoid ElectricalP0749 Pressure Control Solenoid IntermittentP0750 Shift Solenoid A MalfunctionP0751 Shift Solenoid A Performance or Stuck OffP0752 Shift Solenoid A Stuck OnP0753 Shift Solenoid A ElectricalP0754 Shift Solenoid A IntermittentP0755 Shift Solenoid B MalfunctionP0756 Shift Solenoid B Performance or Stock OffP0757 Shift Solenoid B Stuck OnP0758 Shift Solenoid B ElectricalP0759 Shift Solenoid B IntermittentP0760 Shift Solenoid C MalfunctionP0761 Shift Solenoid C Performance or Stuck OffP0762 Shift Solenoid C Stuck OnP0763 Shift Solenoid C ElectricalP0764 Shift Solenoid C IntermittentP0765 Shift Solenoid D MalfunctionP0766 Shift Solenoid D Performance or Stuck OffP0767 Shift Solenoid D Stuck OnP0768 Shift Solenoid D ElectricalP0769 Shift Solenoid D IntermittentP0770 Shift Solenoid E MalfunctionP0771 Shift Solenoid E Performance or Stuck OffP0772 Shift Solenoid E Stuck OnP0773 Shift Solenoid E ElectricalP0774 Shift Solenoid E IntermittentP0780 Shift MalfunctionP0781 1-2 Shift MalfunctionP0782 2-3 Shift MalfunctionP0783 3-4 Shift MalfunctionP0784 4-5 Shift MalfunctionP0785 Shift/Timing Solenoid MalfunctionP0786 Shift/Timing Solenoid Range/PerformanceP0787 Shift/Timing Solenoid LowP0788 Shift/Timing Solenoid HighP0789 Shift/Timing Solenoid IntermittentP0790 Normal/Performance Switch Circuit MalfunctionP0801 Reverse Inhibit Control Circuit MalfunctionP0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit MalfunctionP0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
Nissan Specific Trouble CodesCode DescriptionP1105 MAP/BARO Pressure Switch Solenoid ValveP1126 Thermostat FunctionP1130 Swirl Control Valve Control Solenoid ValveP1148 Closed Loop Control (Bank 1)P1165 Swirl Control Valve Control Vacuum SwitchP1168 Closed Loop Control (Bank 2)P1320 Ignition SignalP1211 ABS/TCS Control UnitP1212 ABS/TCS Communication LineP1217 Engine Over Temperature (Overheat)P1320 Ignition SignalP1335 Crankshaft Position Sensor (REF)P1336 Crankshaft Position Sensor (CKPS)P1400 EGRC Solenoid ValveP1401 EGR Temperature SensorP1402 EGR SystemP1440 EVAP Control System Small LeakP1441 Vacuum Cut Valve Bypass ValveP1444 Canister Purge Volume Control Solenoid ValveP1445 EVAP Canister Purge Volume Control ValveP1446 EVAP Canister Vent Control Valve (Closed)P1447 EVAP Control System Purge Flow MonitoringP1448 EVAP Canister Vent Control Valve (Open)P1464 Fuel Level Sensor Circuit (Ground Signal)P1490 Vacuum Cut Valve Bypass Valve (Circuit)P1491 Vacuum Cut Valve Bypass ValveP1492 EVAP Canister Purge Control/Solenoid Valve (Circuit)P1493 EVAP Canister Purge Control Valve/Solenoid ValveP1550 TCC Solenoid ValveP1605 A/T Diagnostic Communication LineP1705 Throttle Position Sensor Circuit A/TP1706 Park/Neutral Position (PNP) SwitchP1760 Overrun Clutch Solenoid Valve (Circuit)
