Main oil seal replacement on s14
Dazzla
Have you guys replaced the main oil seal on your s14s? between the transmission and the differential is the one im reffering to...can you do it on the car or do you have to pull of the diff?
tramp_drift240
Car: 1992 240sx SE Coupe
the thing between your transmission and differential is your driveshaft.
Dazzla
oops i meant the one between driveshaft and diff
