Main harness replacement / Soldering !
Dan300TT
Car: 1990 Z32 Twin Turbo
Hi guys, Been having some problems with my Z and searching the net came across this site so i figured i would join up, nice to meet you all!
My 1990 TT had the fuse box cut out of it (with scissors) by an angry EX girlfriend. the fusebox in at the front right of the hood, which hasHEADLIGHTS , RAD FAN, AIR CON, EGI ? , IGNITION COIL, THEFT, HORN? The thick chunk of wires going into the front bumper are poking out an inch or two ..enough to rejoin them all. I have just fitted a brand new wiring specialties EFI harness and completely rebuilt the motor (The EFI harness was cut too), and i have all the relays in a box in the order they was sat in the car with the wires poking out of them. My question is this; Does anybody know which relays i will have to install first to get the car to even fire up? then i can work on headlights etc. as i go aslong. I heard somewhere that the relays in that box power the air flow meter and CAS ?
Any help is very much appreciated.
Thank you in advance,
Daniel
elecfus
sure, here you go. you might be better off buying a new harness.
you will need pretty much all of the wires connected for it to run.
DCaff300ZX
Car: .
1993 CRP TT- Modified
Holy crap, and she's still with us??? Kidding...sort of... :wtf2:
Hopefully the info elecfus supplied helps, you have one difficult job ahead there...good luck!
