Main Harness question
mrzabala
Car: 93 Nissan 240SX SE Hatch
Info=1991 240sx se 5 speedremoved complete a/c assemblyremoved radio assembly
What I planned on keeping was my rear tailights, side markers, center console,and fuel pump wiring. I started unwrapping the electrical tape and started putting the wiring I dont need to one side and putting the wiring I need to the other side (keeping all the ground). I also had to cut some of the wires since they were spliced together with the tailights and grounding. Alright as of now Im almost done stripping the wiring harness (organizing it and removing the electrical tape). Before I go beyond to the driver kick panel with all the fuses and boxes, will there be a problem if I removed the whole main harness from the front of the door all the way to the rear? The help is much appreciated. Thank you.Heres what the wiring kind of looks like right now. Most of the plugs have been labeled. And I have the FSM ready but would like to know if there will be any issues.
Modified by mrzabala at 11:12 PM 11/12/2006
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
dont think so as long as its properly labeled. your system seems failsafe so its all good.
mrzabala
Alright So sometime this week Ill try and and remove the wiring I dont need. Im probably going to the electrical store tomorrow so Ill get some wire loom for you too Rob. Thanks, now I feel relieved that Im not going to ruin my main harness hahaha. Oh and hows your car?
jdm_master_X
ultra stiff. so stiff the welded diff CLINGS to the floor, making it really easy to slip. its kinda scary, but still awesome.
