main fuse blown??
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
Spooled_GTIRSENTRA
Car: 04 Sentra Spec V, 93 sentra with GTI-R (sr20det) swap
a while ago i had to replace my main harness because when i got the motor the stock one was hacked. i bought one from a guy with the same engine swap 93 sentra w/ gtir sentra. he had an safc 2 installed in it before he sold me it. he cut the wires so i could wire in an afc easy and can see all the wire colors. i wired it up and it did nothing, then i noticed that the red wire (power) wasnt wired up. it didnt have the power wired through the ecu so i looked the diagram in the afc manual and shows what the pinout is for my car. it said to connect the red wire to the ecu power source, so i did. after everything was wired i tryed to turn the acc on so i could do the inital info on the safc2. when i turned the key everything shut off. i dont have dome lights or horn or anything anymore. nothing works! what could it be? is there a main fuse that everything runs too, or could i have blown the ecu? i must have the worst luck ever, this car has had every problem imaginable!!
nametakennow
Car: '06 MINI Cooper S
It sounds like you cut the ECU power wire. Without being able to see it it's hard to diagnose. Did you hear any noise when you first turned the key?
Spooled_GTIRSENTRA
i herd a snap, the wire it was supposed to be was the ignition power and it was really the ecu power source...
Spooled_GTIRSENTRA
so i went to my car today to work on it to try to figure out what happend. i open the door and the light came on, i was confused!! then i put the key in and turned it, all the gauges lit up... it is like nothing happened!! but i still dont know where to wire my power wire for my safc2. because the one i wired it to last time didnt work!! any ideas?
nametakennow
Do you have the SAFC manual? It has a picture of the pinout and instructions.
Spooled_GTIRSENTRA
yeah, i put the power to the one the manual told to.. it was supposed to be the ignition power but on the pinout i have it says its the ecu power source. the pinout doesnt say a ignition power on it. is there any other place i can wire it to?
nametakennow
Then look at your pinout and find the ECU power.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
