Main Engine Harness Rubbing Against Lowe Battery Tray
luskinj
Car: 2010 Rogue SL AWD
So I have a 2010 Rogue SL AWD that on Tuesday morning started smoking from under the hood and lost all power.
The insurance company took a look and let me know that the main engine harness cover had been rubbing against the lower batter tray over a period of time. This rubbing cut through the cover, eventually exposing the wires. The exposed wires ended up contacting the lower battery tray which caused some large electrical damage.
Has anyone had this happen to their Rogue? What was the result because this isn't covered by insurance and I'm concerned Nissan and the dealership may not take ownership for the issue.
I also found the following which to me shows they knew of the issue:
ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:BELTS AND ASSOCIATED PULLEYS
Date Reported
MAY 18, 2012
NHTSA Reference
#10044039
TSB Reference
#NTB12-043
Description: NISSAN: IF FOR ANY REASON THE ENGINE HARNESS IS REPLACED, DURING THE REPLACEMENT OF THE HARNESS, INSTALL A RUBBER PROTECTIVE PAD ON THE BATTERY TRAY SUPPORT BRACKET. *JS UPDATED 5/24/2012 *JS
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
man, i am really sorry to hear this. i have not heard of this before, but it does seem to be know "known" to nissan if they made out TSB.
where in NJ
Return to “Rogue Forum”
