Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sat Jun 04, 2005 1:57 pm
the DE uses a single coil to drive the spark plugs, where as the DET uses the ignitor chip to drive 4 coils.
I'm trying to remember if the DE got the inbound coil like our 95+ KAs. The S13 KAs had the seperate coil, but the S14 got an integrated coil/distributor. If it does, I believe you have to put a dropping resistor inline to the coil. Other than the coil being slightly different, you might be able to get away with using the stock KA harness and not having to tear it up badly to get everything to work.
