Mahle Piston Review
TRBOMOFO
Car: S13.5 built redtop
found it
Hijacker
Car: '92 240sx Convertible
'94 F-150
Be sure to take a picture of the bottom of your pistons. I want to see if the squirters hit the same place as mine.
The skirt shouldn't contact, but you can tell from the burring where the squirters hit. I had one squirter sort of survive. It had a deformity that spaced the nozzle off to the side away from the support. It only partially cracked at the base instead of being knocked off.
TRBOMOFO
okay i will do that once i get the motor out which i plan to in the next week or less
i had all knocked off one did fall somewhere and get beating into 4 different pieces
Hijacker
'94 F-150
Those look a lot better than the ones that came out of mine. They were all broken into multiple pieces, as well as being mashed and mangled.
TRBOMOFO
damn those little buggers are hard to fine
NOBODY had any
enjuku racing had 2slowboy racing NAphase2motortrend NAthenismoshop NA240sxmotoring NAjgy.cc 2 used ones
so i guess i got my 4
everybody elese either had back order or 8 weeks of JDM downtime
ab-inj
Car: s14a
any update on this problem if its solved by engineers? i have ordered a set of Mahle last week for my sr20, even after reading this thread, cant wait till get tehm!
Hijacker
'94 F-150
I sent all of my pictures and findings to Mahle. You can call the Piston Power Pack division and ask the engineers there if they bothered to redesign the pistons. However, if they didn't or they found that the issue wasn't something that could be solved via changing the design, you'll have to alter the squirters like I did.
ab-inj
Car: s14a
sure i will if its necessary!
i will update next week if they do now this cutout
ab-inj
Car: s14a
Mahle still sucks wit this interference
brewmeister
Car: 1995 240SX with S13 SR20DET / 2006 Pontiac GTO
Talked to Mahle today - they have not changed piston design and suggest reclocking squirters.
Justin35ll
Car: s13 coupe sr20det
bleh i was gonna order these pistons too.. Seem like great pistons, but I'de rather not have to cut the locating pin off and clock the squirters. I don't know yet.
garagelu
Car: 1995 240sx w/ sr
I would definately consider mahle. I know when I was working at Caterpillar Tech Center, I saw that they use mahle pistons on most of their engines. It sucks that they haven't revised this issue.
People are running cp pistons and having great luck with them. I hope mahle will correct this issue so they can compete.
smelly240
Car: 240
mine are reclocked without issues...
22psi pump gas
rps13sh
Car: 1991 Nissan 240SX Super Hicas
why is 1/3 of this page cut off for me? anyone else having this problem? i cant see the right side of this article. cuts off with the stupid search/control panel.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
I'll fix it.. It happened with the software change over when there were quotes inside quotes..
FIXED... It was some work, but it was a really good post, so I felt it was worth it..
rps13sh
great post. thanks for the fix. are ALL the pics fixed? some on pg.2 still look cut off.
SxMachine
Car: Im on a horse
I am curious about what factors cause some squirters to make contact and some not to. Is it all load? Could it also be rod strength or maybe even which main bolts are used (stock,arp) that brings the piston closer to the squirter? Obviously mahle hasnt changed the design because this isnt a issue for them or the motor they tested the pistons in isnt under full load
Hijacker
'94 F-150
Mahle's motor they used didn't have squirters if i remember correctly. The piston is a generic design, they just alter the dimensions to work on a moor, slap it in to check clearances and then release the product. It sounds a bit half assed, but mahle designs a really good piston.
The issue withthe squirtersnwas that they barely contact the inside supports of the piston. Especially once you count heat expansion into the mix. The easiest solution I could devise was to simply reclock the squirters. Tge part is never under load, so there is no issue with shaving that peg a little bit
SxMachine
Car: Im on a horse
Just curious but why not shave the squirter nipple off? Or is the piston contacting the squirter in another place. From the pic it looks like contact is made with the actual nipple. I mean I'm sure shaving it down would alter the oil spray slightly
Hijacker
'94 F-150
You could try to shave the nipple down, I suppose. But reclocking them is a better alternative I believe.
SxMachine
Car: Im on a horse
I'm sure reclocking is a better solution and i'll prob end up doing this over plugging or shaving them dwn.
