thedevguy wrote:The movement of the magnet induces an electric current in the copper and with electric current comes a magnetic field, which makes the magnet attracted to it. The magnet doesn't stick to the wall as it falls because the induced current, and its corresponding magnetic field, and perfectly distributed so that the magnet feels magnetic force equally from all sides.
The magnetic field slows the magnet, but can't stop its fall because if the magnet stopped moving, the induced electric field would go away and the magnet would start falling again.
Also, magic.
Nope that's not it.AZ89two4Tsx wrote:Is it because the copper is not 100% pure and might have some other metal in it?
Nope, not it either but your close.alms24sebring wrote:I bet if it were horizontal it would float in the pipe. Looks like the only reason why it falls is because of gravity overpowering the magnetic forces.
Took a 4 hour 300 level E&M class for my physics degree. You look it upDattebayo wrote:You look it up. and post something about it.
Yup, magnets and currents can be used to accelerate as well. Ever hear of a rail gunalms24sebring wrote:So what you are saying is that the current it induces by moving through it is slowing it down through the pipe from the attraction, or repulsion, of magnatism.
^ Yep. Thats what rollercoasters use to launch from a stop as well (Superman)
You're a physics teacher?bigbadberry3 wrote:Took a 4 hour 300 level E&M class for my physics degree. You look it upDattebayo wrote:You look it up. and post something about it.
It's not like I took an oath lol.frapjap wrote:Dattebayo wrote:You look it up. and post something about it.
