Magnetic sensor or doomsday switch?
ludoZici
Car: 1993 300zx 'vert, 234k and kickin'
I'm cleaning up a '93 vert, in the midst of replacing the upper roller arm in the driver's side I discovered a switch/sensor dangling behind the handle.
I found a thread indicating it might be a magnetic sensor associated with the security system, a part of the handle, but didn't have any images showing where it went.
Can someone confirm this, or is it some other interesting component I need to replace?
Thanks in advance!
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Pretty sure the doomsday switch looks like this...
doomsday switch.jpg (19.66 KiB) Viewed 559 times
Did you find anything about it in the FSM?
https://www.nicoclub.com/service-manual ... 93_FSM.pdf
