That is the exact one I bought online. It works great. After changing my oil after around 8000 miles even though I was going for 10,000 but had the oil change itch, the plug did not look no where like the one pictured there, thank god! It just had a slimy consistancy or goo-like stuff on the tip. ( not the oil )
I believe it was some minute particles in there most likely. Moreover, I have the basic filtermag that has 75 pounds of pull. Hmmm, might update to the more powerful one someday. Never can be too safe.
When you place the magnetic plug into the hole, it's so strong that it tends to attach strongly to the side of the hole when trying to screw it in. You really have to get a good grip to put it in correctly. Also make sure to do the counterclockwise than clockwise routine to make sure the threads are lined up.
I like using these magnetic plugs and magnets on the oil filter because it seems to work and catch certain metals from the online research I have done beforehand.
Plus it makes me feel all warm and fuzzy inside.
I give it a two
I think most mechanics and car people for that matter would know about magnetic oil plugs and consider it a legitimate auto mod.
