Great! thanks for the info, any idea what type of hose to use? does it need to be special for the trans fluid?3Q Jay wrote:yep, i use the 3/8 ports. the hose is ~11/32, so it is overstretched a tad. Haven't had any leakage issues though in 11+ cumulative service years (across the Q's).
3Q Jay wrote:to be more precise i should have said the factory hose is ~11/32. I put the factory hose on one end and used bulk between the filter outlet and the cooler. you can use bulk power steering hose--suggest using nitrile,and NOT the epdm rated hose.
