MAFS trouble Need Help!!
InfinQ4591
Car: 1991 Q45
i have tried everything. Even Wes's MAFS cleaning steps. The problem is not the MAFS, but the connector. About every 40 miles (every time i make a stop somewhere) i will have to get out of the car and push the connector in firmly too avoid stalling, bucking and bad idle. dealer said to get new connector i would have to get a new wiring harness. does anyone know if i cut and splice a connector off an 95 Q could i use it on a 91Q
96Qowner
Car: 1996 Q45
Joe used to have the connector parts 1-888-216-5328:
zerothread?id=135741
****Connector Part Numbers****
38751-123 Pins (you need 3) $1.54 ea38751-112 Connector Shell $17.08Total: $21.70
And no, a 95 won't fit your 91. You need a 90-94.
Modified by 96Qowner at 9:53 AM 9/5/2006
InfinQ4591
Car: 1991 Q45
damn i love this club. thanx man ill order it today so i might finally be able to take it on a road trip
goody90q45
Car: 1992 Infiniti Q45 (sold)
Before you change out your connector- Do you still have the metal 3-sided clip that locks the male to female MAF connections together? From what you described it may be missing. It looks just like the clips on the injectors, CAS, EGR solenoid, etc. If it's missing you can probably fab one up from a stiff piece of metal wire.
Peterofdevon
Car: 94T 70K, miss mannors, 96 Black on Black 72K, raw sex
Just strip the wires and solder it. Take ya 10 minutes.
Peter
Q45tech
Yea! Use a really big plumbers or welding torch so you melt the MAF.
Study the older MAF thread where they destoyed the MAF and ecu making a simple fix ..................only took a month + to get the Q running again.
As we say owners and shade tree techs do more to destroy working Q than any defect.
Just get the correct parts to assemble a new MAF connector and bedone with this problem for another 7 years.
Peterofdevon
Q45tech wrote:Yea! Use a really big plumbers or welding torch so you melt the MAF..
Duh!
25 watt soldering iron will do fine and some lead wire...or go and get a new connector and harness.
Peter
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
Are you saying that the connector cannot be soldered? The soldering gun I use could only melt plastic if in contact for several minutes.
As to the "simple fix" didn't that owner cut the wires with the MAF connected and with power to the car? If that is what you're referencing then this is a poor example to demonstrate your point. Properly using a soldering gun to fix an electrical connection is in no way comaprable to cutting the wires to an electrical device that has power to it.
heywier427
Car: 91 Q45
duck tape fixes all. and if you want to get fancy, you can use one of those black zip tie thingys...
InfinQ4591
Car: 1991 Q45
goody94q45 wrote:Before you change out your connector- Do you still have the metal 3-sided clip that locks the male to female MAF connections together? From what you described it may be missing. It looks just like the clips on the injectors, CAS, EGR solenoid, etc. If it's missing you can probably fab one up from a stiff piece of metal wire.
yeah the clip is still there but it still allows the connector to move around a couple of mm
InfinQ4591
Car: 1991 Q45
thanx everybody for the suggestions bout i ordered the parts from joe yesturday he said they'll be here with in five days. thanx all
Aus94Q45
Car: 1994 Q45
You solder the new pins to the wires and then push them into the connector. The gun will not melt the new connector as you will not have to expose it to the gun. I continue to be amazed by the resistance to the simple repair by many Q owners. The factory pins were not soldered, but merely crimped. The crimping releases and breaks loose over the years. There is no fix other than to replace the connector. No duct tape or wiggling with "repair" it. You are doing the right thing and you will not have this issue in the future.
Q45tech
"You can lead a horse to water......................................................"
Some owners are gluttons for punishment
heywier427
Car: 91 Q45
DEE TE DEE!
InfinQ4591
Car: 1991 Q45
hey guys i just got the parts from joe today. before i go and just cut off the old connector and splice wires for the new one is there any tricks or tips i should know
Q45tech
Read the old thread about not doing it with car running and shorting out MAF and ecu and taking a month to fix car..........summary!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
InfinQ4591 wrote:hey guys i just got the parts from joe today. before i go and just cut off the old connector and splice wires for the new one is there any tricks or tips i should know
Did you read Aus94Q45 post above?
Leave the ignition off! Better yet, disconnect the battery.
