virus77 wrote:would it be smart to go ahead and buy a z32 maf anyways and not have it max out and still use teh pressure sensor for tuning via load, or is it not worth the money if the pressure sensor is going to be there.
if you have a Z32 maf, then you simply don’t need the pressure senor, however consider the following
you will need to find one (easier said then done), pay 100+ dollars on it (same price as the pressure senor) the maf will be used and abused, and might not work properly, pressure senor is plug and play, while the maf will have to be rewired and accounted for when tuning.
