mafs question
race420
Car: 92 240 coupe
hello, i believe the mafs is faulty in my 92 240sx. Anyway I have my hands on a 96 q45 mafs. It appears in alldata that the voltage outputs are approx. the same between the two sensors, except the q45 one maxes out 1 volt higher at 4. Does anyone have any experience retrofitting the q45 sensor into a 92 240sx? Im just looking for a few tips before waste an hour or so trying to hook it up. Thanks.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
The voltage curves are VERY different...despite what the idle and WOT voltage readings are.
You need an S-AFC to make it work.
It may idle, and it may drive (I doubt it)...but it won't do either very well.
- Brian
race420
Car: 92 240 coupe
alright then. I didnt want to hook it up anyway. Where do you get the curves data? I know the service manual does not supply them.
