mikeh16 »
https://forums.nicoclub.com/mikeh16-u19705.html
Sat Jan 22, 2005 9:45 pm
Okay, so the only way I can get the car to idle by itself was to disconnect the MAFS and then it will idle perfectly. I switched out the CA MAFS for the SOHC MAFS. I rewired the connector for the 3 pin connector like so:
Black---> BlackBlack/White---> Black/WhiteWhite---> Green/Yellow and Green/Black
When I plugged it in, it still ran roughly and super rich. Would not idle on its own and would not start without me pumping the gas. Should I get another MAFS from the junkyard and try that? The SOHC MAFS was working perfectly when I swapped out my KAE motor, so I thought that it would have been fine.
Also, while limping the car back to my shop, I noticed the radio turn off, then a couple minutes later my digital speedometer turned off and the car died and I had to pulloff to the side of the road. I just let it sit for like 10 minutes and then got back in the car and it started right back up like nothing happened, but about another mile down the road, it did the same thing. Either the alternator isn't charging the battery fast enough, or the battery isn't holding a charge very well. I'll switch the battery but if anyone has experienced either of these problems before some advice would be greatly appreciated.Thanks,Mike
