cvc9216 »
https://forums.nicoclub.com/cvc9216-u5588.html
Sat Jan 28, 2006 1:11 pm
I pretty much finished up the rb25 swap into my 95 and it will not run with the maf plugged in. Idles fine w/o it plugged in. For some reason the signal output is 12v. I thought it was a bad MAF, so I tried another, and another, and then one more. So I figure I can't have 4 bad MAFs in a row. They all did the same thing, they show 12v when plugged in. It drops to zero when unplugged, so I don't think it's a short in the wiring.
I've tried another ecu also. The wiring harness was in my other car and worked fine. The only thing I changed was the mafs plug. I switched from a Z32 back to stock RB. I've checked the wiring a dozen times. If you're looking into the mafs, the order should be power-signal-ground, correct? I'm pulling my hair out, any ideas?
