this is my first post ,and I dont mean to jack this thread.I too seem to have the same problems described .I just got my first ca18det running ,its stock exept for ssautocrome fmic cheapts know i I and im using k24e maf .it will only idle when I dissconnect the MAF. It will not rev past 2000 rpm,I know this is a clear indication that its a bad MAF.I have an n60 maf ,will this work without chipping ecu. I just want to be sure. I also pulled codes and got code 34 knock sensor,will this code cause the same problematic symptoms?i checked for continuity sensor to engine ground and it failed,I am going to replace knock sensor tomorrow.I have an sr20det in my other car. I know they are completely different motors so im still learning about the ca ,this last and final question do I need to install wallbro 255 fuel pump with FPR, is this engine safe with stock 240 fuel pump? I know i rambled on, any help will be appreciated.rico05 wrote:If it runs the same with the MAF unplugged or not and it will not rev past 2K RPM, it is a MAF. Also, have you checked for codes? If you Search, you can find out how to wire in a KA24E MAF, but it is not an exact swap. It will run, but it will lean out a little in the top end. Your other option is finding a CA MAF or wiring in a N60 or up and chipping for it.
