I just recieved the trouble code 12. Which means its the MAF sensor is the problem like I suspected. What was weird is I have 2 ECU's and 2 MAF sensors. 1 orig MAF and 1 orig ECU, The other MAF is a 89 and the other ECU is a 93. I have mixed matched all of them and started the engine up, and i still get the same result . The problem was still there. And yeah the ECU wasnt the problem. As of now, ALL of my ORIGINAL parts are now inside my car. . Anyways, Im looking to buy this MAF since this small puny island has NO GOOD JUNKYARDS click here
http://cgi.ebay.com/ebaymotors...19855
Do you think this MAF will solve the problem ? I am uncertain about it because of the fact that I already used my friends 89 MAF. I am also thinking it is the wires connecting to the MAF that could be bad also. I did read on about the proper Volts for the wires and i think i might have to check on that soon. But if it is the wires thats bad, Would the car even run? And would it make that much of a difference if the wires are changed? Thanks for your time and effort, Im glad somebody out there enjoys Nissan's as much as I do.
