MAFS issue
skillzilla
So anytime I put ANYTHING on the MAFS, the car wants to bog down and die. By anything I mean anything, filter, coupler, my hands cupped around it, etc. I moved the MAFS all around to make sure the wiring wasnt shorting out with movement, and I checked for vacuum leaks in the intake hose, nothing. Could this be just a weak MAFS?
gawdzilla
Car: none
maybe your idle is just set too low, or you're running way rich causing it to be finicky and bog down easily.
i noticed that when you cup the maf, close the hood, etc., the idle will change a bit but it should settle out after a few secs.
skillzilla
I just adjusted the idle, tried with the filter on and no dice. Checking for codes tomorrow to see if whats goin on, but its running the same otherwise, so Id assume not super rich or anything.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Have you checked the MAF according to the FSM troubleshooting procedure? Also, when is the last time you cleaned it out?
skillzilla
cleaned it out yesterday, its brand new looking. Havent trouble shot it yet, maybe Ill do that today.
27RB240
Car: 92 240sx coupe
Really didnt want to do this but I might as well, JJ has it came in yet???? And do you still have the link from the 240sx meet????Shoot i wanna see em again, I lost it.......thanks
rb240det
Car: 1991 240sx Hatchback and 1994 300zx
I had a similiar problem with my RB20. Turned out to be uber-fouled plugs. Never did get a really good tune on the car...
skillzilla
27RB240 wrote:Really didnt want to do this but I might as well, JJ has it came in yet???? And do you still have the link from the 240sx meet????Shoot i wanna see em again, I lost it.......thanks
has what come in yet? Im so lost bro...
As far as the meet goes, check on csramotorsports, the pics should still be up.
27RB240
Car: 92 240sx coupe
Well I thought u had ordered some stuff, and talked to greddy about the emanage........
skillzilla
ooohhh right, nope no word yet, we'll see.
