mafs bad or not???
revlis
Car: 1992 240sx HB
ok i've searched till my fingers bled still no luck. My only question is does anybody have a definitive answer on how to tell if your mafs is broken or not? (not trying to be a d**k just frustrated lol)
my 240 ka will run fine mafs unplugged (limp mode) but as soon as i plug it in it will stall within 5 or 10 seconds and if i try to give it throttle it only stalls faster. i've cleaned it with mafs cleaner, checked the wires etc. problem is
wish i knew someone near me that had a 240 so i could borrow their mafs for a second but i donthelp, suggestions please
thanx nico
Miller White
Car: 1989 240sx
start your car and let it warm up a lil, fold back the rubber around the maf plug in and take a volt meter/checker wat ever you wanna call it and check wire one. thats the wire all the way to the left if your lookin at it plugged in it should read from 1.0-1.4 volts.
agrigsby240sx
Car: 1995 Nissan 240sx SE
you might have a bare wire, or like he said just test it with a multi meter if you have a manual for your car it will give you all the info and step by step to check it out
vancouverbc
Car: 1991 240sx
it runs better without maf? i think that is the most definitive way to test it.
revlis
Car: 1992 240sx HB
vancouverbc wrote:it runs better without maf? i think that is the most definitive way to test it.
true that would be definitive (smart-*** lol ) it's just frustrating to think about spending $250-400~ for that part. do any of you know of another mafs i can switch out, i know the z32 one oem is $200 but still cheaper. ideas?
thanx guys
kaktus
Car: 95' Nissan 240sx
my car had a bad maf. i replaced it with a used oem MAF that i bought from one of Nico members. only cost $40 shipped. S14
Miller White
Car: 1989 240sx
ya i paid 250 to replace mine when was in the shop back in my dumb days. the next week i started searchin junk yards and found like 3 and stole em. ask around people have some for sale all the time.
Denko44
well a great way to check is to take off the maf and start the car up and if the idle is super low and its sputtering hella and or stall then a bad maf and if you have no difference and how your car acts with or with out the maf, then its probly bad too, also u could check the voltage and grounds like already mentioned above
revlis
Car: 1992 240sx HB
thanx guys i ended up checking junk yard, none for 240 but found one on a stanza, similar size mafs housing, same bolt pattern. so i cut back the wires to see.. same wires too, hooked them up using butt connectors (going to solder) works . car runs and i can give it gas again run like it use to.
i plan to convert to z32 or the one from jwt when i upgrade my ecu but for $3 you can't beat it with a stick thanx again
