JDMskrilla »
https://forums.nicoclub.com/jdmskrilla-u123533.html
Sun Sep 06, 2009 7:27 am
So i checked my codes and got a p0100(maf circuit) so i traced it to my signal wire. But, when i cut open the wire loom from the screw on the fan shroud to the maf plug there are three wires. black(ground) white/black(power) and white(signal wire). the signal wire and the black wire are joined together and again insulated. when I opened this insualtion to separate the two wires to see if they were cut, melted etc. i found a third bare wire no insulation.
So. after a long story my question is what is the bare wire. The wiring diagrams show only the three insilated wires (black, black/white, white).
