MAF Voltages?? (Searched)
djsonic
What are the voltages on the maf supposed to be on a 91 240. Also which wires do i check the voltages with.thankssean
bruinbear714
Don't remember what it is at idle, but it should be 0-5V.
rush0
I've never seen above 4v, not sure if that means mine is bad
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
If i recall the voltage should be around 1.3-1.5v at idle, maybe a little lower but not under 1v.
bruinbear714
rush0 wrote:I've never seen above 4v, not sure if that means mine is bad
If your car is NA, that's normal as the MAF was designed to have some headroom... under boost @0.5bar, I'm almost maxing out my MAF.
djsonic
ah ok thanks for the infosean
