i disagree, the voltage coming out of the maf can be fine, however if the MAF is not reading the airflow volume correctly the power loss will be signifigant.. ive had numerous nissans at the dealership with nearly the exact same issue( no power past 4500k and up.MAF voltage is only one area the ECU looks at coming from the MAF..if the Mass Air Flow measured in cubic feet per minute is not correct this problem he is having is also possible...in fact very possiblemello88 wrote:Yeah 1v/1000mv at idle. Your #s sound very close to the #s they specify in the FSM. Was MAF not plotted on that chart? And out of curiosity, what voltage does it max out at?
I don't think it's your MAF this time. How is your base timing?
Yeah MAF voltage is plotted on that chart. I'll try and get a better chart later. The highest I've seen that MAF is around low 4V.mello88 wrote:Yeah 1v/1000mv at idle. Your #s sound very close to the #s they specify in the FSM. Was MAF not plotted on that chart? And out of curiosity, what voltage does it max out at?
So your saying, replace the MAF. What does the ECU also read? Current?S14-NEO wrote:
i disagree, the voltage coming out of the maf can be fine, however if the MAF is not reading the airflow volume correctly the power loss will be signifigant.. ive had numerous nissans at the dealership with nearly the exact same issue( no power past 4500k and up.MAF voltage is only one area the ECU looks at coming from the MAF..if the Mass Air Flow measured in cubic centimeters per minute is not correct this problem he is having is also possible...in fact very possible
Will do, thanks alot.S14-NEO wrote:honestly i would test with a known good part,i see you have a power FC so why not try bumping up to N62 MAF and give that a go....its worth checking for sure.
lmao!!!!...it is cfm...couldnt tell ya why i said ccm...wow...this day must be wearing on me...heheDarius wrote:The way most Nissan MAF sensors work is with a hot-wire. The wire is kept at a constant temp. The voltage required to maintain that temperature is how the computer interprets the mass flow of air passing through the housing. So as air flow through the MAF increases, it takes more current to keep the wire temperature up, which translates into a higher voltage reading to the ECU. ECU sees higher voltage = more mass. The mass is calculated based on the MAF scale for the particular wire and housing size. That is where the unit conversion comes into play. I highly doubt the maf reads in cc/min since that would probably be in the millions. I think you mean cfm.
Found this article that explains hot-wire MAF sensors pretty clearly:http://www.wellsmfgcorp.com/pd...2.pdf
LMAO ya never knowDarius wrote:Must be from my busted fuel injector thread. Still got your brain on cc/min LOL
