MAF Voltage output question
Taz83
Car: '92 Nissan 240sx Hatch
KA24DE-Turbo
Guys I've been searching for the last 2 days and I've had most of my questions answered but I still need a little more information.
I'm running an S13 KA-T hatch with an Enthalpy chip tune, walbro pump, and an N60 MAFS. My problem is a really rough idle and massive amounts of unburned fuel. If I unplug the MAFS, the idle stabilizes and runs smooth but obviously I'm in limp mode after that, no revving above 2500. The moment I plug the MAFS back in, right back to s*** idle and dumping fuel.
So far I've done the full tune up, got a new injector (went bad a few months ago), and today I got a reman MAFS that I got from CarQuest. Still the same problem.
I tested the wires from the MAFS harness to the ECU, they ohm out just fine, 0-0.1 ohms each wire. I have 12v to the power wire, but here's where I need a little clarification.
Please tell me if I'm doing this correctly, but in order to test the signal output from the MAFS, which is the white wire, I'm putting my red DVM lead on the white wire and the black lead to a body ground. Is this the proper way to test for signal output from the MAFS?
The only reason I'm asking is because when I test it this way, I'm getting a reading of 10 volts. My understanding is the signal output should be between 1-5 volts. What are the chances that this reman MAFS I got is defective?
Guys any help is appreciated, I have to leave soon for Florida from Chicago and I'll be driving down. I need to get the car running again. Prior to this, the car was running absolutely fine, albeit a little low on power and a light stumble here and there. This all just happened in the last 2 days. Otherwise I gave everything a check over just a couple months ago when I replaced the bad injector. Also good compression all the way across, mid 170s psi range with a 2-3 psi variance between all 4.
Thanks for any info you guys can help me with.
PapaSmurf2k3
Site Admin
This is one of the better diagrams I've found:
Basically yes, voltage read from that signal wire to ground (any ground) should be 0-5v, depending on airflow. With the car off and ignition ON, it should see something like .4v. Idle should be .5-.55ish
Do you have your old MAF to try out?
Taz83
KA24DE-Turbo
Nah, turned it in for the core already. Thanks for confirming I was testing it the right way. I've double and triple checked the wiring, all seems fine. I'm really hoping the new MAF I got is defective. Once I get the next replacement, if that doesn't work, assuming I'm correct about the wiring, what's the next thing to look at, ECU?
PapaSmurf2k3
Site Admin
ECU or the connector I suppose.
Realistically you should be able to hook the MAF up to straight battery (or a battery charger/12V power supply) I would think, and measure the signal voltage with it not even hooked up to the car.
