270whpTY_DOHC91 wrote: At what point in my turbo charging adventure would i be maxxing out my stock 91 240sx maf?
and at that point, what should it be replaced with in combination with an emanage?
thank you,Nismo_Freak wrote:
270whp
Z32 MAF
Not quite... you need the following:TY_DOHC91 wrote:thank you,
Is that a bolt on, plug&play thing?what all does that include?
35 min south of portland
Ok Is there an adapter for the maf harness or are we talking jumping pins?I suppose that somewhere there is a diagram of exactly how to do this?Nismo_Freak wrote:
- Way of mounting it... 3" IN/OUT along with a different bolt pattern for filter- Wire in the MAF plug to the stock harness- Correction for Airflow via S-AFC II / ROM Tune / etc.
Yes.ElNegro wrote:Don't you have to have the z32 plug, and hard wire the wires from that into the harness???
