MAF test
blind6
Car: was a 1997 Infiniti Q45
Is there a way to test or ohm a MAF?
blind6
Anyone?
goody90q45
Car: 1992 Infiniti Q45 (sold)
Do a search for "MAF" in Infiniti Online Mechanic and you'll find what you need.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
only way to truely tell if the MAF is bad is to swap on a new one.
Q45tech
I spot bad MAF by viewing a chart and graph of the MAF voltage vs WOT rpm and comparing it to a chart of a good MAF of course correcting the numbers for ambient temperature.
I have a special place where I can easily measure 3500>redline.
The changes are not dramatic as 0.2 volt is significant at 4.34 volts.
The ecu follows the MAF as long as the reported voltage makes sense and is within +- 20% of what is expected for rpm and load.
Not cut and dry but it gives me a feel before I order a new MAF from dealer.
blind6
I think this is gonna be a trial and error process, since I don't have all the diagnostic things I need in the garage and I can't risk driving all over. This is crazy since all the problems my Q is having are pointing to a couple of problems. I'll keep posting up with my progress. MAF is on the way so I'll do the clip at the same time. I think the alt will be last.
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
Will a 1990 MAF work in a 1995?
elwesso
2007 BMW M Coupe
Yeah it should as long as the 95 MAF has the same connector.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:Yeah it should as long as the 95 MAF has the same connector.
Which it doesn't.
