Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Aug 07, 2004 11:43 am
The graph of the voltage vs air flow is exponential [to the 3.5 power].
The only way to know for sure is to compare units. EXACT equal conditions of RPM and TPS voltage [engine load].
X voltage of MAF will create Y millisecs of injector opening time at Z rpm with Q units of TPS voltage.
Easier to test HP peak rpm at WOT load ~~ 4.0 volts.
They don't give exact voltages because the MAF voltage will change with temperature, altitude [barometric pressure], and humidity.
The ecu won't throw a code if the MAF seems [+-30%] close but not very accurate.
