Nali »
https://forums.nicoclub.com/nali-u88675.html
Tue Dec 08, 2009 1:58 pm
The Maf being bad?Yeah it could cause sputtering and very bad idle.
The ECU would probably panic and enter limp mode if the Maf was completely f***ed.
Clean the MAFS and make sure its wired correctly and try again.
If the problem still persists, get a known working MAFS and plug it to the engine and see the results.Once you have verified that it is or isnt the MAFS causing the problem troubleshoot the next item.
