GraySilvia »
https://forums.nicoclub.com/graysilvia-u3605.html
Mon Nov 03, 2003 1:45 pm
The SOHC KA maf is a direct replacement. Also the MAF on the KA powered Stanza's is the same. It certainly sounds like your MAF if bad or the wiring is wrong. When I tried to start my car with the Z32 MAF for the first time, it was pissed, shot fire, popped, smoked, etc. A rewire cured it sure as it could.
As far as sheilded wire, it's a good idea to extend it with shielded wire, but I can't see it would affect it THAT much. See if you can borrow someone's correctly operating MAF and see if that helps.
