Xit40 »
https://forums.nicoclub.com/xit40-u25227.html
Fri Jul 09, 2010 9:22 am
Finished the rewire and cleaned up all the wiring at and around the ECU plug today. Got everything installed back in as it should be, bolted down, plugged in, etc. Hooked the battery back up, put the key in the on position and bam 9.85 volts again....CRAP.
So as I'm sitting there dumbfounded thinking everything over: I know it's wired right, grounded correctly, brand spanking new shielded wire and everything; I walk into my basement and pull out the extra ECU that came with my front clip. Yes, that's right, when I ordered the front clip they sent an extra ECU because the original one had a small dent on one of the covers. It was only cosmetic damage, but hey that was nice of them. I'll gladly take extra free parts whenever the opportunity arises.
I originally checked both ECU numbers, even though RB25DET M/T was clearly printed on both ECU's, and found them to both be good ECU for my motor. Sweet. So I plug in the alternate ECU and bam.... .28volts with the car on the on position. I have no idea what kinda hokum is going on with the first ECU I tried but there is obviously some kinda short internally or some other nonsense wrong with it. Thank god I had the extra ECU or I don't know what I would have done.
