maf SENSOR
waynecox35
Car: 1993 q45
I am looking for a MAF sensor anyone have any suggestions as far as new vs used and what brands work well with my 1993 Q45
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
New is not cheap at ~$500 and OEM used are the best way to go?
What makes you think yours is bad?
scottq45
Car: 1994 Infiniti Q45
I pulled one from a 94 Q45 in a pull and pay and cleaned it following the instructions on Q45.org site and put it my Q and it worked fine. Check your local pull and pays. A used one would run about $235 plus the core from the auto parts store. The pull and pay was about $30.00 bucks if I remember. It was real easy to pull off. If you can't find one they just brought a 93 into our local pull and pay. Let me know we can work something out.
waynecox35
Car: 1993 q45
Infinitiguy19 wrote:New is not cheap at ~$500 and OEM used are the best way to go?
Car was stalling and bucks every now and again so I took it in for a look and the guy told me MAF sensor "tested weak" I cleaned it and it improved slightly but now the problems are back.
waynecox35
Car: 1993 q45
scottq45 wrote:I pulled one from a 94 Q45 in a pull and pay and cleaned it following the instructions on Q45.org site and put it my Q and it worked fine. Check your local pull and pays. A used one would run about $235 plus the core from the auto parts store. The pull and pay was about $30.00 bucks if I remember. It was real easy to pull off. If you can't find one they just brought a 93 into our local pull and pay. Let me know we can work something out.
That would be great if one is available please let me know. Thanks in advance!
JCampbell
Car: 1991 G50 Q45
Hey I have two working MAF's let me know if you are interested.
waynecox35
Car: 1993 q45
JCampbell wrote:Hey I have two working MAF's let me know if you are interested.
yes I am.....shoot me a text 513-295-6447, thanks
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Check the wiring and connector first. MAF don't fail except at very high mileage or air filter abuse.
