MAF sensor
aukword1
Car: 04' g35, 04' rx8
anyone ever use an MAF sensor cleaner on their g? i bought a cleaner i'm just wondering if its safe to use on the actual sensor...any thoughts?
Infiniti Chica
Car: 2004 Sedan- Sport package
The sensor is very delicate, but what I've used in the past has been to dip a q-tip in alcohol and gently, I mean gently, clean the insides. I've also been known to use Contact Cleaner Quick Dry only. At all costs, never touch the sensor directly with your fingers. CRC MAF Sensor Cleaner is new and less prone to dissolving other components in the MAF sensor. Do yourself a favor and remove the MAF sensor from the vehicle before attempting to clean it. Also, I'd make sure the air filter housing, air filter and all associated ducting are intact, clean inside and not leaking dirt. This will keep you from needing to clean or replace the MAF sensor anytime soon.
The process is fairly easy, but requires a delicate touch and no intrusive neighbors like Vern coming over to check on you. Make sure that whatever solvent you use leaves no residue whatsoever.
As a side note, K&N filters have been known to leave oil deposits on the MAF sensor, so I've been reluctant to use it (plus I'm not sure it's really all that great as a product.
One quick point, I'm no car expert, so I'm sure someone else here will chime in and point out something I might have left out or mis-stated.
telcoman
aukword1 wrote:anyone ever use an MAF sensor cleaner on their g? i bought a cleaner i'm just wondering if its safe to use on the actual sensor...any thoughts?
aukword1
Welcome to NICO
INMHO replacing your air filter at regular intervals will do much to keep your MAF clean. My experience has been never try to fix anything that isn't broke. My air filters seem to get pretty dirty after 8-10k miles. It is a 15 min job to change them and they tun about $10.00.
Telcoman
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
Most oil based fiters won't actually foul the MAF. This was covered at great length in the Maxima forum at one point. I actually advocated the use of a non oiled filter like an AEM Dryflow. I have since learned a lot about the filters, and read some pretty cool stuff. I will link you when I am able to find the articles. (I'm sick, and doped up on cold meds and pain killers, searching the netz isn't happening right now)
The sugestion about the CRC MAF cleaner I agree with. That's what I have used, and had no problems with it. I personally won't touch the element with anything. Fingers or a Q-tip. I'm not that gentle or brave. I just spraw it down a lot, until it looks clean.
aukword1
yea thats what i have.. the CRC MAF cleaner...should i use it directly on the sensor itself like it says? and the part about not touching it my fingers....will the CRC cleaner clean that if it were to happen?
aukword1
i dont use K&N, i have an AEM cold air intake with a bypass valve.... so there are no oil deposits on it....but since i took it all off to install a plenum spacer and clean the throttle body i thought i might as well clean it while its off...
Beancooker
Just spray it directly on the element. Don't get it too close, because the pressurized fluid *could* damage the element. Yes, it will clean it without touching it. I'm sure it will clean it faster if you do touch it, but I personally wouldn't. Just be generous with the can. It's only like $5, so if you use the whole can, big deal.
aukword1
right okay thank you alot i'll try it out and see what happens lol
Beancooker
Cool. Be careful, and good luck.
You should take some pics and write an article about how to clean the MAF. I'll give you a custom title for it, as long as you write a good article.
aukword1
yea i could do that... i'll work on it and start a new thread...prolly take me about a day or so.
smockers83
Car: 2006 G35 Coupe
Beancooker wrote:You should take some pics and write an article about how to clean the MAF. I'll give you a custom title for it, as long as you write a good article.
Someone wrote one a long time ago or posted a video or something.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
is the MAF really something you need to clean often?
I've never heard that being super important.
Beancooker
As long as you keep the air filter clean, usually it's not that necessary. Maybe every 50k.
telcoman
Beancooker wrote:(I'm sick, and doped up on cold meds and pain killers, searching the netz isn't happening right now)
Beancooker
Try a hot bowl of my chicken soup
Telcoman
Beancooker
That looks so tasty.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
telcoman wrote:
Beancooker
Telcoman
Telco,
How often do you use that picture?
telcoman
Sentientbydesign wrote:
Telco,
Occasionally only when one of our members are sick
joe603
Car: 2014 Durango R/T
^ LOL Telco
