MAF SENSOR..
Andres322
Car: Infiniti i30t 2001
i have infiniti 2001 i30t ... i have ses light on for long time... i have check the code from the dealer.. it said it's my MAF Sensor problem..... do i have replace or clean it?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
That depends on why it failed.
If you're lucky, it'll just be a bad connection. You can try cleaning the harness connector and see if that helps.
As far as the MAF element itself is concerned, there's really no way to tell if cleaning will help or not until you've tried it. Be gentle with it, as it's pretty delicate. Use a quick-evaporating electrical cleaner and steer clear of harsher cleaners. Spray and let dry a few times and see if there's any improvement.
Welcome to NICO!
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
When the MAF goes, you will know!
Starting then stalling, hoping you will make it home.
If is a finiky thing. Mine costs 365$. Dont know if Ihave the guts to mess with it.
If you are getting a code but the car is running fine,it would just clear the code.
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
welcome aboard
yeah check the wires going into the plug that plugs into the MAF. sometimes those have a slight tendency to come loose. beyond that, give it a good cleaning with MAF sensor cleaner and see if that helps.
Andres322
when the enigne is cold.. when i start the car.. it stall all the time... until i press some gas.. and the enigne will run fine.....
Trav1s
Car: 2002 Infiniti G20 Sport
CRC makes a MAF cleaner that works good if it is simply a dirty MAF. It's about $6 stateside and worth a try as it might save you $100+ for a new MAF. The Good thing is the MAF on the 00/01 is less than half the price of the 02/03 MAF for the VQ35DE.
Here is a pic of the can
jmcdonald5103
Car: 2002 Infinity I-35
How do you replace the MAF in a 02 I-35? It looks simple except for the bolt that you can't get to. Do you have to remove some stuff? Also is there anything else I need to do besides just change out the MAF's?Thanks
balasang
Car: 90 Nissan Maxima
I found something on youtube that for me its a good FYI for you and how it works I am too having problem with my MAF .. heres the link below hope will help a bit cuz MAF is not cheap to buy .. I am still thinking if i can in someway salvage it and i know a lil about electronics so hope for the best on both of us ..
http://www.youtube.com/watch?v=sSuL58YEH-E
or just go on youtube and type MASS AIR FLOW and you will see the video ..hope it helps
