MAF sensor swap? Dire need of help!
baughb
Car: 1992 Nissan Silvia S13 Converted 240SX
I just found out why my 240 iddles like a top fuel drag car. It runs through quarter a tank to go to work and home.Bad MAF sensor. None can be found in any junkyard for a 1992 240SX SE within 100 miles of my home, and the local Nissan dealer wants $489.95 for one the cheapest online I found was $120 and its a 50/50 shot. I did find an 89-91 sensor and it was different looking and it went to a SOHC motor. The plugs didn't match either. But the wires going into mine and that one were the same color and they were in the same order.
***Would it be possible to swap a 1989 SOHC MAF sensor into a 1992 DOHC?***
And if so is it true that you must mount it CPU side up because if so i need to fabricate a bracket to hold the new unit because the former ownwer rigged a cold air tube. eveerything is kosher except the sensor.
crypt2k
Car: cars, women, what else.
Not good man.Your maf and cpu have to be of matching years... I learned that the hard way.
But try junkyarddog... I got mine shipped from fl to nj for $75
benemorius
Car: s13, s13, eg, e36
Welcome to Nico. You should have little trouble finding a member in the Shopping Mall section who would sell you one.
zeromain?id=165
zero.counter
Car: ....
I have a 92 MAF available. Slightly polished. How about $50 shipped?
baughb
are you absolutely sure it works?
zero.counter
Car: ....
baughb wrote:are you absolutely sure it works?
Yes it works, but since it is used...it will be sold as is, no warranty implied. Since I am not sure if your car has an electrical issue, I can't take a chance.
Let me know if you are interested.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
http://www.car-part.com
They list a TON of 'em for between $35 and $50...all from junkyards, most have warranties.
Search for "air flow meter" and expand the search range to "southeast"...MAF's are small, and very cheap to ship...so just find one cheap from a yard with a warranty, and pick it up.
- Brian
baughb
money order ok? and who do I make it out to?
