MAF sensor PLEASE HELP! help needed ,QUESTION ANBOUT MAF sensor.. Thankyou..
bboyLT
Car: 240
Hi everyone i accidently pulled out the 3 wires going into my mass air flow in my 96 s14.. I'm not shure which wire goes where? a b or c.. im assuming white wire is to the 5volt signal which is connected to B, black/white 12 volt wire is connected to A, and black wire is ground and conneced to C. am i correct?
it started and idled fine whe I hooked the wires up. but after i accidently touched the black/white wire to medal and it sparked and now the car wont start.. i did a test on the wire and I'm not getting the 5 volts siglan like before..
intresting I'm not shure what is really wrong or maybe i shorted out the computer? when that wire touched real quick. if anyone have a diagram of the wires orcan tell me how to fix this problem.. any help would be appreciated very much thanks. my emal [email protected]
inkslingers13
Car: 1985 Corolla Gt-S
sounds like you might have blown a fuse, check your fuse box.as for wiring a maf, im not sure.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
white to white, black to black and white/black to white/black
bboyLT
Car: 240
hmm i think computer is blown up.. anyone had this situation before.. thanks.
surfer240sx
Car: 90 240sx sr20det
def fried the ecu happened to my sr sorry bout ur luck such a lame mistake can be costly unplug negative on ur battery anytime ur working with eletrical stuff....
