Thanks for sending me the link for the MAF sensor. I do have 1 question though as i've been searching for info all over google n other forums as well. The Delphi sensor you showed me apparently has 5 connector pins and my factory sensor only has 4. I believe i read somewhere that the 5th pin goes to a resistor for INTAKE AIR TEMP or IAT which i believe my truck has a seperate sensor for that alone located in the air filter resonator box. So in other words, will this interfere in the sensors function or performance or you still think it would work fine? In amazon it also asked me to check for fit with vehicle info and when i entered the info for my truck, it says the MAF sensor is compatable with the 02' Pathfinder. Thanks for any feedback in advance once more.atraudes wrote:What year was the Maxima? The MAF used in the 00-02 Maximas are absolutely interchangeable so if it fits you likely grabbed the right one.
The symptoms you describe and the fact it didn't happen before you made the swap definitely point at the sensor. Give the place you got this one from a call and see what their exchange policy is. Most places will let you grab the same part out of a different car if you have problems (with some exceptions). Also, if your engine was running without significant problems with the old sensor, you could try swapping it back in and see if the hesitation problem goes away.
If you end up getting a new one, I recommend the Delphi AF10168. I got mine off Amazon for around $85 and haven't had any problems (Delphi is a great brand in general).
The idle air volume relearn is recommend when you replace parts like this, though it won't make a difference in your case since the problem you're having is well above idle.
Thanks for the info. The car hasnt thrown any codes for the TPS but i'll try and read up on the Nissan ECS manual to see how to troubleshoot the tps. I dont think its bad since i performed the IDLE AIR RE-LEARN process and one of the steps is to disconnect the tps and reconnecting it. When i disconnected the tps the idle went up momentarily but after re-connecting within 5 seconds, the rpm dropped lower and i believe thats the tps functioning properly when performing that step. I'll definitely look into it though.nickelghandi wrote:I had the same issue when I had my 99.5 pathfinder. Check your TPS. In my case both the MAF and the TPS were bad, and that rough shift and acceleration lag sounds like a transmission in limp mode due to the TPS being no good.
Ok. Great info, thanks! I actually "modded" my stock intake as well and removed the resonator box as well as some other small boxes hooked up to the main intake tube and also zip-tied my IAT sensor as well so it wouldnt get damaged from dangling around and stuff. lol. Btw, that "mod" made a pretty decent change in hp/tq combined with the drop-in K&N filter i already had installed. Seems that opening a bigger hole on the bottom of the factory airbox will also yield more hp/tq since the engine is breathing in more cold air yet isolating the heat from the engine bay. Getting back on track, i'm gonna try swapping another tps sensor as suggested above to see if that fixes my issue but apparently everything points to the MAF sensor being defective.atraudes wrote:The fifth pin will simply not do anything as it won't be connected to anything. In fact, a lot of posts I read from people who used Maxima MAF sensors said the ones they acquired had the fifth pin as well. It's interesting to know that the pin is used for intake temperature (great find!). Our temperature sensor is indeed mounted in the resonator and since I installed my K&N intake I've had the temperature sensor simply zip-tied in nearby. It'd be interesting to see if we could tap one of our temperature leads onto the MAF sensor...
tl;dr Yes the Delphi will most definitely work.
Forgot to ask if your pf threw the trouble code for a bad TPS when you had it scanned. When i had mine scanned it threw the P1102 code which is for mass air but no other code. Did yours do the same yet ultimately your TPS sensor was defective as well. Just wanna double check to see if i make a trip to the junkyard for another TPS sensor before i spend $80+ on a new MAF sensor. Thanks.nickelghandi wrote:I had the same issue when I had my 99.5 pathfinder. Check your TPS. In my case both the MAF and the TPS were bad, and that rough shift and acceleration lag sounds like a transmission in limp mode due to the TPS being no good.
