brettsdad »
https://forums.nicoclub.com/brettsdad-u127484.html
Fri Mar 20, 2009 12:39 pm
i had the same problem. i took out my maf to clean it but it wasnt dirty, it looked fine. so i took it apart, you're not supposed to. they do a pretty good job of sealing that thing up. so what i found when i took it apart was two circuit boards, one above another. the bottom one you cant get to but it looked like one of the pins on the top one had come un-soldered. either that or i broke it when i took it apart. so i went to wal-mart and got a soldering iron and some solder and some gasket sealer to put it back together. i re-soldered the part that i thought might have been the problem, sealed it up, put it back in and it runs great. cost me 12 bucks and took an hour. my car used to die at stop lights and even moving at slow speed. it started out as just a high low idle like yours though. hope this helps, good luck!!!
