MAF Sensor and Management Options
joenismos15
Car: 1995 Nissan 240sx SE
Been Looking at getting a New Mass Airflow sensor, Something that wont peak its voltage until maybe 24psi of Boost (Not running that much but i like to have a cushion)
I have looked at the Z32 MAF the Ford Cobra MAF and the Supra MAF.
I am currently running the BLUE E-manage with all the Ignition, Injector and MAP
My question is should i be able to Run one of these MAF sensors with just the e-manage or do i need to get my ECU modded (i.e Jim wolf Enthalpy Etc)
Also Would it benefit the ease of tuning on the E-manage if i got the ECU modded?
And for the Third part of my question which MAF have you had the best luck with? I.e Ease of converting best results etc.
WDRacing
Your best bet is to get the ECU tuned and use the 300ZX maf.
joenismos15
Sounds Good i guess i will give Jim Wolf Technologies a call then
WDRacing
Enthalpy would be my first choice then JW, then EFI Specialists. Only because I don't have anough valid reviews of any EFI Spec tunes. But by all means, check them out and write a review for us.
WD
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
Def. skip out on the emanage blue, you will be better off with a tuned rom(which controls timing while the blue does NOT)
I spent 250 on a road tuned, rom tune + n62 maf, and others charge similar. The n62 maf can also push at least 530whp from what I've seen.
joenismos15
Well i already have the e-manage in there and running, I also have an Ultimate sitting in my garage. I wanted to know if they would work together, (e-manage and ROM tune) Or so that i can have the ROM tune as my "baseline" and Emanage for fine Tuning
Ill look into the EFI also
Also the Emanage Blue With THe Ignition Harness i thought does control timing i could be wrong but i though that was the point of the ignition harness?
Right From Greddy's Website under the E-manage Blue
"If the "Optional Ignition Harness" and the software are used the unit has the ability to control a 16x16 ignition timing map. All of the above maps can also be map-traced in real-time as well. If the factory range of map or airflow meter is surpassed, you can incorporate a larger airflow meter or our "Optional GReddy Pressure Sensor and Pressure Harness" to set larger scales of adjustment."
Modified by joenismos15 at 8:42 AM 4/2/2009
joenismos15
Here are all the Options i have Found So Far
---------------ECU Tuning-----------
Enthalpy http://www.rs-enthalpy.com/
Jim Wolf http://www.jimwolftechnology.com/
Nistune http://www.nistune.com/
EFI Specalist
http://www.efispecialist.com/
--------------MAF Sensor Options-----------------------
Z32 Mass Airflow Sensor (Kits are available for Conversion i.e Tomei)
Ford Cobra MAF (Some JW ecus use this)
Ford Lightning MAF (Some JW Ecus use this also)
Toyata Supra MAF
----------------Piggy Back/stand aloneSystems that can be used------------------
Apexi SAFC
Greddy E-mange Blue
Greddy E-manage Ultimate
Megasquirt (as far as i can tell, Correct me if i am wrong)
AEM EMS
Ill add to this list as i find More!
Modified by joenismos15 at 8:48 AM 4/7/2009
Chris28
Car: 92 s13 KA-T
I have an efi tune and my car runs great. Granted I'm not boosted yet, but I'm running 370cc incjectors so the tune is necessary. Car pulls harder than a stock ka, and I haven't had any startup issues. I'll be installing my wideband next weekend so I can tell you what the afr is like, but I won't be boosted until summer so I'll have to wait until then to see how the ecu does with forced induction.
joenismos15
I think i may try an EFI Tuned ECU, But I Just cant find if they do any custom Tunes or if you have to go with what they have. That factor may make me go with an enthalpy Tune in the end.
k00k904
Car: 91 Nissan 240sx
I have a question if I'm running a aem ems standalone do I even have to use a maf sensor or what?
WDRacing
Nope, you can use MAP.
DevilMB3017
Personally if I had more money to put into my car project it would have an AEM EMS with a MAP sensor tuned by AFR and EGT. I would consider this far superior to other tuning methods, although its overkill for a street vehicle and rather pricey after all is said and done, especially compared to a 500-600 Enthalpy Tune (what I use now).
joenismos15
Also with AEM EMS hope you never have to get it Emissions tested or inspected! It Disables the Dash lights that need to be on and then go off for testing.
Chris28
Car: 92 s13 KA-T
EFI does custom tunes, just tell him what you are running and he will tune for it.
DevilMB3017
joenismos15 wrote:Also with AEM EMS hope you never have to get it Emissions tested or inspected! It Disables the Dash lights that need to be on and then go off for testing.
That's not how that works...Every state's testing programs are different - and in each state it can vary from county to county and even further down.
For example, in NJ you have to get inspect (all working lights, dash lights like check engine, emission and brakes) every two years, no ifs ands or buts. Like everything there are ways around it, but you still need to know the laws locally and what the penalties are for avoiding it.
I've gotten a $120+ fine for no inspection sticker...
JRex
Car: 93 s13 Hatch
Does anyone have any experience with the EFI custom tunes? I was thinking about ordering the Daughterboard upgrade from them, because I don't want to send my ECU off.
WDRacing
There are a few guys here into tuning. Make a new thread or you won't get the best answers.
WD
tegls1
Car: 95 S14 SE, Audi A6 Biturbo
Is it possible run a map sensor from an emanage blue? I am still Na and want to run ITBs.
joenismos15
yes you can run a map sensor from e-manage blue
joenismos15
Another neat little thing i have picked up Was Nissan Data Scan Software and a USB Consult Cable (OBD), Still trying to get it to Work though seems like it can see the ECU but not Communicate with it.
