SanCarlosQ45 »
https://forums.nicoclub.com/sancarlosq45-u89021.html
Fri May 15, 2009 8:57 am
From what it sounds like you are using the oiled K&N filter in the stock air box? The one thing people on this forum mention is that the oil is carried along with the air, thus contacting the surface of the sensor which may or may not interfere with the readings; I am not entirely sure whether this is true or not. I cant imagine that it would kill a MAF sensor, but rather it is the age of the unit along with heat that will stress the internal circuit board and solder joints that will kill it.
I am using the Oiled K&N filter and have not had any noticeable issues related to this. I could be wrong as I don't have any connections to a pristine example, but that shouldn't discount my experience.
It is recommended that if you are going back to paper filters then you should replace it ~ every year, or less depending on the conditions where you live (construction, dusty, how mcuh and where you drive).
