Maf screen question
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
I have the Z32 maf And the metal screen is all messed up. Im sure that i can just rip that mesh off and it will still read air correctly right..??
Im sure its just there for protecting the sensor itself.... but i can be wrong..
j-z
Car: 95 240sx
there was a discussion on this a while back in the tech section. the screen actually smooths out the airflow, so it doesnt disturb the sensor when air is moving through it. try straightening it?
WDRacing
Picture a kitchen sink with and without a screen with the water running through it. With the screen is a nice smooth stream, without is eratic. However, I've run both ways and have never noticed a problem.
What you could do is buy some metal screen at Home Depot or Lowes and bond it to the MAF. I've seen this done and it worked well.
WD
240SicknessX
Car: 96 240 SE
actually i was under the impression that the screen disturbs the flow that the sensor can read it. with the air flowing though the screen it sets a patturn or something that that mafs reads. my uncle has a z32 tt and he removed the front screen on the mafs for some odd reason and the car ran like **** when he tried laying in the throttle. then he put the screen back on without any changes and it ran fine.
I think he was trying to free up some avalible restrictions in the air flow path by removing those.
* i belive that he has removed the rear screen for "better flow" or it was bent or something weird and the car still ran ok, it was when he removed the front screen that it started acting up and didnt want to run right.
Back to what WD was saying about the screen over the kitchen sink. with the screen on there, you can feel the air bubble seperation on your fingers. without the screen the water flows around your finger and you dont feel much of a texture change. you can add water flow or reduce it and not feel too much of a difference in the smooth flow.
having the screen on there, disrupting the airflow helps cool off the hotwire in the mafs, maybe this is nessacary with the design from nissan?
rn240sx
09 Ninja 650R
06 Suzuki S40
I ripped off the screen on both side's.... and running with NO air filter and the idle is smooth as can be..!!
