MAF retrofitting?
blurrbosi
Car: 240's
Will the s1 rb25 maf # O2uOO work on my s2 rb25?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
No, it won't be a direct plug-in. The S2 MAF is a 3-wire and the S1 is a 4-wire both with different plugs. You could rewire the S1 MAF though. Hell, you could go with a Z32 or Q45 if you had engine management installed.
blurrbosi
Car: 240's
thanks. Then I guess I need the maxima maf part number. Any ideas where to get this?
wawazat8402
Car: 89 Sil80- RB25DET
Mine was from a 97 Maxima. I30 should work as well. I believe they are the VQ30 MAFs. Pink label.
EDIT:: It is also the exact same part number as your Series 2 maf. Mine was at least.
