zombieman wrote:he mean converting a maf car to being one that doesn't use one at all. don't listen to your buddy there. the most efficient reading of air flow is done with a maf. so this mean when adjusting fuel with air, it would be within the most accurate ratio oppose to a car that doesn't run a maf. yes it's restrictive, but this system of monitoring air flow is used in almost every fast car you can think of.
The MAFS can also cause a lot of trouble if it's malfunctioning. Bad signals from a MAFS can cause an engine to run really bad. That's why some high end tuners convert to D Jetronic which uses a Manifold Air Pressure (MAP) system which eliminates the MAFS altogether. With this setup you can run an atmospheric BOV. This is for really high 500+ hp applications. It is much more expensive, but computers like the Power FC D Jetro and the HKS FCON VPRO (the absolute top of the line) eliminate the MAFS
