MAF REPLACEMENT
Larz
Car: 2019 Q70-L RWD
I cannot work out how an MAF sensors can be "OEM quality" and cost between $25 and $190 ???
Obviously I reckon I'd NOT go with a $25 part, but the more I look, I see $50, $80, $100, etc. The dealer OEM part is over $200, so even allowing for the obligitory dealer mark-up, how can there be such a bloody huge range in price?
Wll the $50 MAF perform ike the $200 MAF? Is it best to replace with an Infiniti MAF and if not, how cheap can one go and still expect a qaulity MAF?
Any advise is appreciated.
aiham78
Car: 2011 Infiniti M37x
I was always told by Infiniti and independent mechanics not to go cheap on the sensors and go with OEM only as they will last and save you labor, time and money in the long run.
No personal experience, not yet :crazy:
EdBwoy
If it's deep in the engine, I go with OEM. If it's easily serviceable I give priority to the warranty offered. Of course this depends on what else could be affected down the line if you get an inferior quality part, example a cheap IACV that could kill an ECU
psyopper
Car: 2006 M35x
Consider yourself lucky. The MAF for my 1995 Hardbody KA24 just cost me $350.
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
First get rid of the cheapest and second cheapest. After that do research and go manufacturer reputation instead of price. After that's said...I don't know what an MAF is, but that's how id go about buying a part I'm not sure about unless someone could recommend a specific one. Good luck.
Larz
Car: 2019 Q70-L RWD
TDot wrote:First get rid of the cheapest and second cheapest. After that do research and go manufacturer reputation instead of price. After that's said...I don't know what an MAF is, but that's how id go about buying a part I'm not sure about unless someone could recommend a specific one. Good luck.
So glad you said that! I, also had no earthly clue what MAF meant either until I asked in here. It's the Mass Air Flow sensor - the little gizmo that sits on the intake tube near the throttle body. I have no issue with mine but it's 8 years old and I want to replace it now along with some other things that are easy to get to like belts, hoses, etc. I have no problem with using OEM Infiniti parts where its needed, but the wide range of prices for other brands did my head in and I was wondering why.
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
Hey Larz,
If you need to change out the Mass Air Flow sensor (MAF), you can go to Infiniti Parts USA...they sell OEM parts at competitive prices...here's the link to the MAF (item 14) just under $200. Or any reputable company will suffice...
http://www.infinitipartsusa.com/2007-In ... earching=Y
Or you can just maintain your current MAF by unscrewing two small screws at the MAF housing, and using MAF cleaner (I clean mine every 2 - 3 weeks)... very easy to do....
http://www.autozone.com/autozone/access ... fier=36011
Frog
Car: 2011 Infiniti M56 S
You said there is nothing currently wrong with your maf. Why replace it. Especially with an non oem part.
It's like going to the dentist and asking all your teeth be pulled out just to get dentures. When there's nothing wrong with your current teeth.
Larz
Car: 2019 Q70-L RWD
Fair point, Frog. I see your point, but I was thinking this way: We don't wait till the hoses or belts break to change them out, we change them in advance of them blowing. I have no clue how long an MAF is expected to last but I know mine is 7 years old and has 90k miles on it. Seems high so I decided to consider changing it out now. I'm having the plugs replaced too, for the same reason.
BTW, I still have my OEM teeth - minus one that has a small white filling on top, LOL
Larz
Car: 2019 Q70-L RWD
CPJ LB wrote:Hey Larz,
Thanks for the links, CPJ !
Larz
Car: 2019 Q70-L RWD
Thank you for the advise / opinions one and all !
jiggersplat
Car: 2008 Infiniti M45x
1995 Toyota Supra TT 6-spd
Larz wrote: So glad you said that! I, also had no earthly clue what MAF meant either until I asked in here. It's the Mass Air Flow sensor - the little gizmo that sits on the intake tube near the throttle body. I have no issue with mine but it's 8 years old and I want to replace it now along with some other things that are easy to get to like belts, hoses, etc. I have no problem with using OEM Infiniti parts where its needed, but the wide range of prices for other brands did my head in and I was wondering why.
There's no point in changing if you're not having a problems with it. Just take it out and clean it using MAF/air intake cleaner from your local autoparts store. Depending on the type, they can be easily damaged so be careful!
Frog
Yes the maf doesn't start to fail like belts and plugs. It either works or doesn't.
Great news on your teeth. I am pretty sure the plugs in our cars are good for 100k so at 90k now would be a good time. Anyone care to chime in. I think the belts are good for 100k as well. ??
Wangtang408
Car: 2006 Infiniti M35
Frog wrote:Yes the maf doesn't start to fail like belts and plugs. It either works or doesn't.
I just got my 60K services and belts were include, plugs are done at the 105K service. I ordered the NGK Iridium under $40 and paid $50 to have them put in. Dealer asking $200, save over $100!
Larz
Car: 2019 Q70-L RWD
Thank you all again for the advise and opinions. Great to have you lot to bounce ideas. I'm not gonna mess with the MAF aside from cleaning it and just do the plugs and belts for now.
fat3oy
Car: 07 M35X, 06 350z, 06 RSX, 99 Dajiban
MAF SHMAF! Never had a crap quality maf, they are pretty much all made by the same manufacturer... Even the upgraded ones are just tweaked oems... Hop on my350z and grab a used one. Or hop on ebay and grab one for a G35, 350z, or M... Any VQ35DE will work... MAF is easy peasy...
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
Uhmm not sure if I'm buying 100k on those plugs I had a miss fire going on and I replaced all six ignition coils and plugs. My mechanic said the plugs were in bad shape car has 74K I only run 93 octane and sits all winter
And about the MAF doesn't the idle need to be reprogramed after that's changed?
fat3oy
lovemycarM35 wrote:Uhmm not sure if I'm buying 100k on those plugs I had a miss fire going on and I replaced all six ignition coils and plugs. My mechanic said the plugs were in bad shape car has 74K I only run 93 octane and sits all winter
It is a good idea to, but unneccssary as your maf should be plug and play, disconnecting the throttle body requires a reset... You can do the Idle reset yourself... there is a guide somewhere around here... it is button press, gas press, sequence to reset.
