Mint Q45A »
https://forums.nicoclub.com/mint-q45a-u39580.html
Sat Mar 31, 2012 11:15 am
A month or so ago my car started bucking and almost dying for no aparent reason. It was very random; would do it for a few seconds,only once or twice a week.....Typical symptoms associated with a MAF malfunction.
After cleaning and tightening the connector the issue went away...only to come back a week or so later.
I was getting ready to look for a used MAF, but decided to take a chance and try "to look inside the MAF": I removed the top plastic cover (flat ,square) - I carefully removed the "ruberry" seal around the border and pulled the top.
By doing this I got access to the three electrical connections between the internal parts and the wires that go out to the terminals in the external connector. I decided to re-solder these connections.....Put the cover back; applied a heavy bead of black RTV around the edge to seal it back,....
The whole thing took me 20 min. or so...
The car has been running with no issues since then....I actually get the impression that the shifting is smoother now...
I thought this could help others experiencing similar issues....
