*MAF QUESTION* z32 on KA
(Q)240
Car: 92 240sx s13 Coupe
i hear ppl put the z32 *300zx* maf on 240's But is it ok to put it on a Regular KA24de.... will it fit... and what parts are required to put it on other than the MAF it self... also, does it help & how...
I tried lookin for sum answers but it was not easy... so im just asking to see if anybody can give me sum info on this....
ShootToKill
Car: S13
define regular KA24de. i'm confused in your wording?
(Q)240
stock.... with only an AEM intake...
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
(Q)240 wrote:i hear ppl put the z32 *300zx* maf on 240's But is it ok to put it on a Regular KA24de.... will it fit... and what parts are required to put it on other than the MAF it self... also, does it help & how...
Don't do it! The Z32 MAF will not give more HP on an OEM setup; it will screw up the ECU's fuel map usage and you'll end up with less HP along with driveability problems.
To use a larger MAF, the ECU needs to be re-programmed. This is what the turbo guys do for greater air flow which is needed.
smurf13
Car: 1992 Nissan 240SX fatback
just get a safc
