MAF QUESTION
72nismo
Car: 510 / G35 / Murano
If you turn your car on and disconnect the MAF what does your car do?
Will it continue idling normal.
Start stuttering?
OR ????
moneymike
Car: 1991 nissan d21 hardbody
you can disconnect it i dont suggest you do it while the car is on id say do it before you start it then turn it on.
the car will idle not normal thought it will drop and jump
and the car wont rev past 2.5k or so
72nismo
When the car is on its stuttering and turning off. But when we disconnect the maf the car idles normal. At this point my car is not wanting to stay on. So at this point dont know whats wrong with the car.
ka-t4u
how is your iacv hose?? had similar issue and it was all my fault... forgot to connect the iacv hose to the intake tube before the maf....
moneymike
id still say change the maf. had that problem on my boys boosted spec wouldnt start/stay on with the maf connected, then once we disconnected it started up fine but wouldnt rev past 2.5k would break up. so we put a scanner to it didnt say much but maf wasnt reading right volts. so we pulled one from his other spec worked perfect
and like that problem was solved
72nismo
Thanks for replies we finally figured it out my plenum came apart from the bottom. Re welded it and problem solved.
ka-t4u
glad to hear you got it sorted out!
